yesterday I stored a simple MOD-UI setup (only dexed with tinyamp) as the default.zss setup. After rebooting it is loaded and I can play, but my encoders and the screen is freezed.
Has anyone else such a problem or do I have a broken pedalboard?
Ok , i found something more precise: The real issue is not on default snapshot but the snapshot itself. It can’t manage an entire pedalboard loading. Practically: MOD, being a plugin host, is quite complex, like a “zynthian inside a zynthian” , and the right call sequence should be: zynthian snapshot>pedalboard>mod Ui, something like we open an app by double clicking his project… Is It possibile?
First of all: i tried installing beta lv2 plugins and tried helm in particular: it’s gorgeus! Thanks for this. I’m still not able to do plugins installation on my own… i appreciated you find the same things … About this, i saved a snapshot with mod and Helm, and is recalled almost fine… There is always some weird behaviour, but something works… So maybe It could depend on pedalboard/plugin complexity
I made tests after I updated the box. My issue still exists.
Just create a snapshot with two instances of the same plugin and zynthian-ui can’t handle it anymore.
Instead of having two instances you could “toggle-select”, you get two presets. But they don’t hold the proper values. So once you just try to change anything in the box, you misconfigure the pedalboard.
