7 original LV2 Plugins by open-music-kontrollers.ch
Perhaps someone can make use of these plugins:
https://open-music-kontrollers.ch/lv2/about/
The Sherlock utility reports: Atom,MIDI & OSC Events, at it’s input.
I’m fuzzy about tailoring LV2s for Zynthian, do his Linux version have to be custom complied for the processor. (There is github source) Do all LV2s in the wild require translation for Zynthian?
Would the Mod Duo plugin development package make compatible LV2s?
His main open source project music controller project, a “poly-magneto-phonic theremin” is a bit like a theremin with a guide scale, hovering height over a keyboard image, controls volume.
https://open-music-kontrollers.ch/chimaera/about/#Software
It’s played with magnets worn like rings, giving 2 notes from 2 hands. He is aiming for low latency high data rates, only interfacing through Ethernet connectors (SNTP).
You can find demo audio and vide files here:
https://open-music-kontrollers.ch/chimaera/media/
Thanks for sharing, @MaxMaxis!
Could you open an “issue” in the “zynthian-sys” github repo?
This is the better way that some developer take the task of testing the plugins in Zynthian and creating an “install recipe” :wink:
