EDIT: I had to ctrl+c because it keeps looping the same.
I believe the line “wiringPiISR: pin must be 0-63 (111)” is the error ?!
X.Org X Server 1.18.4
Release Date: 2016-07-19
Build Operating System: Linux 4.4.26-v7+ armv7l Raspbian
Current Operating System: Linux zynthian 4.18.7-v7+ #1 SMP Fri Sep 14 08:48:48 CEST 2018 armv7l
Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=800 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Build Date: 11 November 2016 11:59:59AM
xorg-server 2:1.18.4-2+rpi1 (https://www.debian.org/support)
Current version of pixman: 0.33.3
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Sat Apr 20 18:25:45 2019
(==) Using config directory: “/etc/X11/xorg.conf.d”
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
INFO:root:No Wiring Layout configured. Only touch interface is available.
DEBUG:root:ZYNCODER A: [100, 103, 108, 111]
DEBUG:root:ZYNCODER B: [101, 104, 109, 112]
DEBUG:root:SWITCHES layout: [102, 105, 110, 113]
WARNING:root:Using default DISABLED MIDI IN ports
DEBUG:root:ENABLED_MIDI_OUT = [‘ttymidi:MIDI_out’, ‘QmidiNet:in_1’]
WARNING:root:Using default ENABLED MIDI FB ports
INFO:root:ZYNSWITCHES INIT…
INFO:root:SETUP ZYNSWITCH 0 => wpGPIO 102
INFO:root:SETUP ZYNSWITCH 1 => wpGPIO 105
INFO:root:SETUP ZYNSWITCH 2 => wpGPIO 110
INFO:root:SETUP ZYNSWITCH 3 => wpGPIO 113
INFO:root:ZYNTHIAN-UI OSC server running in port 1370
INFO:root:STOPPING QMIDINET
DEBUG:root:ZCTRL ‘Layer’: 0 (0 -> 7), None, None
Zyncoder: Zynswitches poll thread created successfully
ZynMidiRouter: MIDI tuning frequency set to 440 Hz (8192)
PNG file: /zynthian/config/img/zynthian_logo_error_ip.png - Application must supply a known background gamma
/zynthian/config/img/zynthian_logo_error_ip.png is 320x240 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4545
Zooming image by 200%…done
didn’t find evidence of prior run.
Merging…done
Building XImage…done
Merging…done
Merging…done
Merging…done
xinit: connection to X server lost
waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
xinit: unexpected signal 2
root@zynthian:/zynthian/zynthian-ui/doc#
