Hi -
I did “apt-get update && apt-get upgrade” via ssh, and now the display on the Zynthian is dead - no splash screen at boot time, no UI. This is a v3 kit that was working fine until today. The webconf is still working as normal. I tried Sofware → Update, thinking i was missing some pre-req or dependency or whatever - it completed fine but made no difference.
Here’s the UI log that I retrieve via webconf. I noticed errors like: “error: failed to open file /zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl (No such file or directory)”, and sure enough those files are missing. But I don’t know if that’s the root cause or symptom of something else.
All hints appreciated. Thanks.
–R.
-- Logs begin at Fri 2020-10-16 15:23:31 BST. --
Oct 16 18:20:45 zynthian startx[6027]: Terminated
Oct 16 18:20:45 zynthian startx[6027]: identify-im6.q16: unable to open image `/zynthian/config/img/fb_zynthian_error.png': No such file or directory @ error/blob.c/OpenBlob/2874.
Oct 16 18:20:45 zynthian startx[6027]: expr: syntax error: unexpected argument ‘100’
Oct 16 18:20:45 zynthian startx[6027]: expr: syntax error: unexpected argument ‘24’
Oct 16 18:20:45 zynthian startx[6027]: convert-im6.q16: invalid argument for option `-pointsize': -fill @ error/convert.c/ConvertImageCommand/2359.
Oct 16 18:20:45 zynthian startx[6027]: /zynthian/config/img/fb_zynthian_error_ip.png: image not found
Oct 16 18:20:45 zynthian startx[6027]: didn't find evidence of prior run.
Oct 16 18:20:45 zynthian startx[6027]: Building XImage...done
Oct 16 18:20:50 zynthian startx[6027]: lilv_world_load_bundle(): warning: Replacing version 2058.0 of <http://gareus.org/oss/lv2/b_whirl#extended> from <file:///zynthian/zynthian-plugins/lv2/b_whirl_xt/>
Oct 16 18:20:50 zynthian startx[6027]: lilv_world_load_bundle(): note: New version 2071.9 found in <file:///zynthian/zynthian-plugins/lv2/b_whirl/>
Oct 16 18:20:50 zynthian startx[6027]: error: failed to open file /zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl (No such file or directory)
Oct 16 18:20:50 zynthian startx[6027]: lilv_world_load_file(): error: Error loading file `file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl'
Oct 16 18:20:50 zynthian startx[6027]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl
Oct 16 18:20:51 zynthian startx[6027]: error: failed to open file /zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl (Not a directory)
Oct 16 18:20:51 zynthian startx[6027]: lilv_world_load_file(): error: Error loading file `file:///zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl'
Oct 16 18:20:51 zynthian startx[6027]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl
Oct 16 18:20:51 zynthian startx[6027]: error: failed to open file /zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl (Not a directory)
Oct 16 18:20:51 zynthian startx[6027]: lilv_world_load_file(): error: Error loading file `file:///zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl'
Oct 16 18:20:51 zynthian startx[6027]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl
Oct 16 18:20:52 zynthian startx[6027]: Cannot connect to server socket err = No such file or directory
Oct 16 18:20:52 zynthian startx[6027]: Cannot connect to server request channel
Oct 16 18:20:52 zynthian startx[6027]: jack server is not running or cannot be started
Oct 16 18:20:52 zynthian startx[6027]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Oct 16 18:20:52 zynthian startx[6027]: libjackpeak failed to start jack client: 17
Oct 16 18:20:52 zynthian startx[6027]: identify-im6.q16: unable to open image `/zynthian/config/img/fb_zynthian_error.png': No such file or directory @ error/blob.c/OpenBlob/2874.
Oct 16 18:20:52 zynthian startx[6027]: expr: syntax error: unexpected argument ‘100’
Oct 16 18:20:52 zynthian startx[6027]: expr: syntax error: unexpected argument ‘24’
Oct 16 18:20:52 zynthian startx[6027]: convert-im6.q16: invalid argument for option `-pointsize': -fill @ error/convert.c/ConvertImageCommand/2359.
Oct 16 18:20:52 zynthian startx[6027]: /zynthian/config/img/fb_zynthian_error_ip.png: image not found
Oct 16 18:20:52 zynthian startx[6027]: Building XImage...done
Oct 16 18:20:57 zynthian startx[6027]: lilv_world_load_bundle(): warning: Replacing version 2058.0 of <http://gareus.org/oss/lv2/b_whirl#extended> from <file:///zynthian/zynthian-plugins/lv2/b_whirl_xt/>
Oct 16 18:20:57 zynthian startx[6027]: lilv_world_load_bundle(): note: New version 2071.9 found in <file:///zynthian/zynthian-plugins/lv2/b_whirl/>
Oct 16 18:20:57 zynthian startx[6027]: error: failed to open file /zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl (No such file or directory)
Oct 16 18:20:57 zynthian startx[6027]: lilv_world_load_file(): error: Error loading file `file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl'
Oct 16 18:20:57 zynthian startx[6027]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl
Oct 16 18:20:58 zynthian startx[6027]: error: failed to open file /zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl (Not a directory)
Oct 16 18:20:58 zynthian startx[6027]: lilv_world_load_file(): error: Error loading file `file:///zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl'
Oct 16 18:20:58 zynthian startx[6027]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl
Oct 16 18:20:58 zynthian startx[6027]: error: failed to open file /zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl (Not a directory)
Oct 16 18:20:58 zynthian startx[6027]: lilv_world_load_file(): error: Error loading file `file:///zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl'
Oct 16 18:20:58 zynthian startx[6027]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl
Oct 16 18:20:59 zynthian startx[6027]: Cannot connect to server socket err = No such file or directory
Oct 16 18:20:59 zynthian startx[6027]: Cannot connect to server request channel
Oct 16 18:20:59 zynthian startx[6027]: jack server is not running or cannot be started
Oct 16 18:20:59 zynthian startx[6027]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Oct 16 18:20:59 zynthian startx[6027]: libjackpeak failed to start jack client: 17
Oct 16 18:20:59 zynthian startx[6027]: identify-im6.q16: unable to open image `/zynthian/config/img/fb_zynthian_error.png': No such file or directory @ error/blob.c/OpenBlob/2874.
Oct 16 18:20:59 zynthian startx[6027]: expr: syntax error: unexpected argument ‘100’
Oct 16 18:20:59 zynthian startx[6027]: expr: syntax error: unexpected argument ‘24’
Oct 16 18:20:59 zynthian startx[6027]: convert-im6.q16: invalid argument for option `-pointsize': -fill @ error/convert.c/ConvertImageCommand/2359.
Oct 16 18:20:59 zynthian startx[6027]: /zynthian/config/img/fb_zynthian_error_ip.png: image not found
Oct 16 18:20:59 zynthian startx[6027]: Building XImage...done
Oct 16 18:21:04 zynthian startx[6027]: lilv_world_load_bundle(): warning: Replacing version 2058.0 of <http://gareus.org/oss/lv2/b_whirl#extended> from <file:///zynthian/zynthian-plugins/lv2/b_whirl_xt/>
Oct 16 18:21:04 zynthian startx[6027]: lilv_world_load_bundle(): note: New version 2071.9 found in <file:///zynthian/zynthian-plugins/lv2/b_whirl/>
Oct 16 18:21:04 zynthian startx[6027]: error: failed to open file /zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl (No such file or directory)
Oct 16 18:21:04 zynthian startx[6027]: lilv_world_load_file(): error: Error loading file `file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl'
Oct 16 18:21:04 zynthian startx[6027]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl
Oct 16 18:21:05 zynthian systemd[1]: zynthian.service: Stopping timed out. Terminating.
Oct 16 18:21:05 zynthian systemd[1]: zynthian.service: Control process exited, code=killed, status=15/TERM
Oct 16 18:21:05 zynthian startx[6027]: xinit: connection to X server lost
Oct 16 18:21:05 zynthian startx[6027]: [1B blob data]
Oct 16 18:21:05 zynthian startx[6027]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Oct 16 18:21:06 zynthian startx[6027]: xinit: unexpected signal 15
Oct 16 18:21:06 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Oct 16 18:21:06 zynthian systemd[1]: zynthian.service: Failed with result 'timeout'.
Oct 16 18:21:06 zynthian systemd[1]: Stopped Zynthian User Interface.
Oct 16 18:21:06 zynthian systemd[1]: Started Zynthian User Interface.
Oct 16 18:21:06 zynthian startx[6217]: X.Org X Server 1.20.4
Oct 16 18:21:06 zynthian startx[6217]: X Protocol Version 11, Revision 0
Oct 16 18:21:06 zynthian startx[6217]: Build Operating System: Linux 4.15.0-99-generic armv8l Raspbian
Oct 16 18:21:06 zynthian startx[6217]: Current Operating System: Linux zynthian 5.4.51-v7+ #1333 SMP Mon Aug 10 16:45:19 BST 2020 armv7l
Oct 16 18:21:06 zynthian startx[6217]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Oct 16 18:21:06 zynthian startx[6217]: Build Date: 27 August 2020 08:51:48AM
Oct 16 18:21:06 zynthian startx[6217]: xorg-server 2:1.20.4-1+rpt2+deb10u1 (https://www.debian.org/support)
Oct 16 18:21:06 zynthian startx[6217]: Current version of pixman: 0.36.0
Oct 16 18:21:06 zynthian startx[6217]: Before reporting problems, check http://wiki.x.org
Oct 16 18:21:06 zynthian startx[6217]: to make sure that you have the latest version.
Oct 16 18:21:06 zynthian startx[6217]: Markers: (--) probed, (**) from config file, (==) default setting,
Oct 16 18:21:06 zynthian startx[6217]: (++) from command line, (!!) notice, (II) informational,
Oct 16 18:21:06 zynthian startx[6217]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Oct 16 18:21:06 zynthian startx[6217]: (==) Log file: "/var/log/Xorg.0.log", Time: Fri Oct 16 18:21:06 2020
Oct 16 18:21:06 zynthian startx[6217]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Oct 16 18:21:06 zynthian startx[6217]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Oct 16 18:21:07 zynthian startx[6217]: ./zynthian.sh: line 55: /sys/class/backlight/*/bl_power: No such file or directory
Oct 16 18:21:08 zynthian systemd[1]: Stopping Zynthian User Interface...
Oct 16 18:21:08 zynthian startx[6217]: Terminated
Oct 16 18:21:08 zynthian startx[6217]: identify-im6.q16: unable to open image `/zynthian/config/img/fb_zynthian_error.png': No such file or directory @ error/blob.c/OpenBlob/2874.
Oct 16 18:21:08 zynthian startx[6217]: expr: syntax error: unexpected argument ‘100’
Oct 16 18:21:08 zynthian startx[6217]: expr: syntax error: unexpected argument ‘24’
Oct 16 18:21:08 zynthian startx[6217]: convert-im6.q16: invalid argument for option `-pointsize': -fill @ error/convert.c/ConvertImageCommand/2359.
Oct 16 18:21:08 zynthian startx[6217]: /zynthian/config/img/fb_zynthian_error_ip.png: image not found
Oct 16 18:21:08 zynthian startx[6217]: didn't find evidence of prior run.
Oct 16 18:21:08 zynthian startx[6217]: Building XImage...done
Oct 16 18:21:13 zynthian startx[6217]: lilv_world_load_bundle(): warning: Replacing version 2058.0 of <http://gareus.org/oss/lv2/b_whirl#extended> from <file:///zynthian/zynthian-plugins/lv2/b_whirl_xt/>
Oct 16 18:21:13 zynthian startx[6217]: lilv_world_load_bundle(): note: New version 2071.9 found in <file:///zynthian/zynthian-plugins/lv2/b_whirl/>
Oct 16 18:21:13 zynthian startx[6217]: error: failed to open file /zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl (No such file or directory)
Oct 16 18:21:13 zynthian startx[6217]: lilv_world_load_file(): error: Error loading file `file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl'
Oct 16 18:21:13 zynthian startx[6217]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl
Oct 16 18:21:14 zynthian startx[6217]: error: failed to open file /zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl (Not a directory)
Oct 16 18:21:14 zynthian startx[6217]: lilv_world_load_file(): error: Error loading file `file:///zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl'
Oct 16 18:21:14 zynthian startx[6217]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl
Oct 16 18:21:14 zynthian startx[6217]: error: failed to open file /zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl (Not a directory)
Oct 16 18:21:14 zynthian startx[6217]: lilv_world_load_file(): error: Error loading file `file:///zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl'
Oct 16 18:21:14 zynthian startx[6217]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl
Oct 16 18:21:15 zynthian startx[6217]: Cannot connect to server socket err = No such file or directory
Oct 16 18:21:15 zynthian startx[6217]: Cannot connect to server request channel
Oct 16 18:21:15 zynthian startx[6217]: jack server is not running or cannot be started
Oct 16 18:21:15 zynthian startx[6217]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Oct 16 18:21:15 zynthian startx[6217]: libjackpeak failed to start jack client: 17
Oct 16 18:21:15 zynthian startx[6217]: identify-im6.q16: unable to open image `/zynthian/config/img/fb_zynthian_error.png': No such file or directory @ error/blob.c/OpenBlob/2874.
Oct 16 18:21:15 zynthian startx[6217]: expr: syntax error: unexpected argument ‘100’
Oct 16 18:21:15 zynthian startx[6217]: expr: syntax error: unexpected argument ‘24’
Oct 16 18:21:15 zynthian startx[6217]: convert-im6.q16: invalid argument for option `-pointsize': -fill @ error/convert.c/ConvertImageCommand/2359.
Oct 16 18:21:15 zynthian startx[6217]: /zynthian/config/img/fb_zynthian_error_ip.png: image not found
Oct 16 18:21:15 zynthian startx[6217]: Building XImage...done
Oct 16 18:21:20 zynthian startx[6217]: lilv_world_load_bundle(): warning: Replacing version 2058.0 of <http://gareus.org/oss/lv2/b_whirl#extended> from <file:///zynthian/zynthian-plugins/lv2/b_whirl_xt/>
Oct 16 18:21:20 zynthian startx[6217]: lilv_world_load_bundle(): note: New version 2071.9 found in <file:///zynthian/zynthian-plugins/lv2/b_whirl/>
Oct 16 18:21:20 zynthian startx[6217]: error: failed to open file /zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl (No such file or directory)
Oct 16 18:21:20 zynthian startx[6217]: lilv_world_load_file(): error: Error loading file `file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl'
Oct 16 18:21:20 zynthian startx[6217]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl
Oct 16 18:21:21 zynthian startx[6217]: error: failed to open file /zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl (Not a directory)
Oct 16 18:21:21 zynthian startx[6217]: lilv_world_load_file(): error: Error loading file `file:///zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl'
Oct 16 18:21:21 zynthian startx[6217]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl
Oct 16 18:21:21 zynthian startx[6217]: error: failed to open file /zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl (Not a directory)
Oct 16 18:21:21 zynthian startx[6217]: lilv_world_load_file(): error: Error loading file `file:///zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl'
Oct 16 18:21:21 zynthian startx[6217]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl
Oct 16 18:21:22 zynthian startx[6217]: Cannot connect to server socket err = No such file or directory
Oct 16 18:21:22 zynthian startx[6217]: Cannot connect to server request channel
Oct 16 18:21:22 zynthian startx[6217]: jack server is not running or cannot be started
Oct 16 18:21:22 zynthian startx[6217]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Oct 16 18:21:22 zynthian startx[6217]: libjackpeak failed to start jack client: 17
Oct 16 18:21:22 zynthian startx[6217]: identify-im6.q16: unable to open image `/zynthian/config/img/fb_zynthian_error.png': No such file or directory @ error/blob.c/OpenBlob/2874.
Oct 16 18:21:22 zynthian startx[6217]: expr: syntax error: unexpected argument ‘100’
Oct 16 18:21:22 zynthian startx[6217]: expr: syntax error: unexpected argument ‘24’
Oct 16 18:21:22 zynthian startx[6217]: convert-im6.q16: invalid argument for option `-pointsize': -fill @ error/convert.c/ConvertImageCommand/2359.
Oct 16 18:21:22 zynthian startx[6217]: /zynthian/config/img/fb_zynthian_error_ip.png: image not found
Oct 16 18:21:22 zynthian startx[6217]: Building XImage...done
Oct 16 18:21:27 zynthian startx[6217]: lilv_world_load_bundle(): warning: Replacing version 2058.0 of <http://gareus.org/oss/lv2/b_whirl#extended> from <file:///zynthian/zynthian-plugins/lv2/b_whirl_xt/>
Oct 16 18:21:27 zynthian startx[6217]: lilv_world_load_bundle(): note: New version 2071.9 found in <file:///zynthian/zynthian-plugins/lv2/b_whirl/>
Oct 16 18:21:27 zynthian startx[6217]: error: failed to open file /zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl (No such file or directory)
Oct 16 18:21:27 zynthian startx[6217]: lilv_world_load_file(): error: Error loading file `file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl'
Oct 16 18:21:27 zynthian startx[6217]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl
Oct 16 18:21:28 zynthian systemd[1]: zynthian.service: Stopping timed out. Terminating.
Oct 16 18:21:28 zynthian startx[6217]: xinit: connection to X server lost
Oct 16 18:21:28 zynthian startx[6217]: [1B blob data]
Oct 16 18:21:28 zynthian systemd[1]: zynthian.service: Control process exited, code=killed, status=15/TERM
Oct 16 18:21:28 zynthian startx[6217]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
