Hello everyone,
I apologise if I’m going to ask a “silly” question but I hope you can help me with that anyway.
I have some issue understanding how to use MIDI FX.
For the Arpeggiator I’m doing this:
set Synth layer on channel 1
set Arpeggiator on channel 2
midi route Arpeggiator to channel 1
I’m able to use the Arpeggiator but the problem I’m facing is that the sounds doesn’t stop when I stop playing the keyboard, I need to remove the layers in order to make the sound stop.
I tried to do the same with MIDI pattern but I’m not able to play any sound.
Same thing with other MIDI effects.
What ma I missing? Could you give me some suggestions?
Thank you!
Also, if you bold select your synth layer (hold the Select knob down for about a second before releasing), you will find an option to “Add MIDI-FX”. If you select the Arpeggiator from that menu, you won’t need the Arpeggiator on channel 2.
