Aruk RC-3 freezes
Very often am experiencing Freezes and a red icon on the ui
My setup :
Pi 3 , 2 channels with a single instrument
Zy and noisemaker engine
The previous stable image worked better with this setup
Please, could you give more details?
  • Are you using snapshots or setting the layers by hand? Could you attach the snapshot with the layer configuration that is causing the problem?
  • How often are the “freezes”? It hapend while playing or also when no MIDI activity?
  • Could you send a log dump? It would be really useful …
Kind Regards!
freezes during both operations: using snapshot and adding new layers
it happens often, nothing works during freez ( not sounds or Ui navegation ) I have to unplug and reboot.
how can I get a dump file to send ?
You can use the webconf tool for accessing the UI log. From there you have to change to debug mode and try to reproduce the error. When you get it, copy the log and send it back to this thread.
Also, on the wiki you will find instructions for doing it from the console, accessing by SSH:
http://wiki.zynthian.org/index.php/Accessing_Zynthian_from_your_computer
Kind Regards
@jofemodo
Logs begin at Thu 2016-11-03 17:16:42 GMT. –
Jul 18 20:22:22 zynthian startx[434]: Before reporting problems, check http://wiki.x.org
Jul 18 20:22:22 zynthian startx[434]: to make sure that you have the latest version.
Jul 18 20:22:22 zynthian startx[434]: Markers: (–) probed, (**) from config file, (==) default setting,
Jul 18 20:22:22 zynthian startx[434]: (++) from command line, (!!) notice, (II) informational,
Jul 18 20:22:22 zynthian startx[434]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Jul 18 20:22:22 zynthian startx[434]: (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Jul 18 20:22:22 2019
Jul 18 20:22:22 zynthian startx[434]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Jul 18 20:22:22 zynthian startx[434]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Jul 18 20:22:27 zynthian startx[434]: libjackpeak registering as ‘jackpeak’.
Jul 18 20:22:27 zynthian startx[434]: libjackpeak created input ports
Jul 18 20:22:38 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 20:29:34 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 20:30:33 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 21:16:08 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 21:21:05 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:27:45 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:28:00 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:28:32 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:28:39 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:28:43 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:28:47 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:28:55 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:29:10 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:29:16 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:29:21 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:29:22 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:29:23 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:29:51 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:29:56 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:30:55 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:30:58 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:31:00 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:31:02 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:31:05 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:31:07 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:31:13 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:31:16 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:47:27 zynthian startx[434]: ERROR:root:Jack Audio XRUN!
Jul 18 22:49:34 zynthian startx[434]: Jack::MidiBufferMixdown - invalid source buffer
Jul 18 22:53:29 zynthian startx[434]: ZynMidiRouter: Error processing jack midi input events: TOO MANY EVENTS
Really curious log-dump! I never saw this error message. Could you give me more details about the MIDI devices you have connected to zynthian?
