Also I’m trying to figure out how in zynthian conect my ext hdd.
Are there some tutorials I can follow, pls.?
I have whent thru the official video channel at youtube, but I guess manual is better. I haven’t found it on the general wiki, or I just missied that out.
Filebrowser credentials: zynthian and opensynth
If is doesn’t work look in /zynthian/zynthian-sw/filebrowser/filebrowser.json
As long as it is an SSD with USB connection: just plug it in. USB-3 is advised, it’s much faster on a RPi5. For a genuine HDD I don’t think the USB port supplies enough power. You could try a powered hub. As you may have expected, there is no SATA port on the kit
For NVMe, you can search the forum; there is a long and extensive explanation in one of the posts. However, I do not think it is supported.
Edit: credentials corrected, I looked at the wrong line
