Banks on Dexed (and other LV2 plugins)
Those who updated software in the last days probably have noted that Dexed presets are now organized in several banks. This is also true for OBXs, although there is only 1 bank, so it doesn’t make a difference, by now …
This change is bigger, and affects all LV2 plugins because i’ve added bank support following the LV2 specs (perhaps i’m the first one doing that, jeje!).
The bad side is that snapshots including LV2 plugins with presets could be partially broken. For fixing them, you should:
  • load the snapshot
  • reselect bank/preset in every LV2 layer with presets
  • save again
