Hi guys,
Here a the steps to reproduce:
- Chose a layer (ZynAdd) for example
- Add a layer: Select the ModUI
- Go back to the layers
- Chose the first layout and then audio => Mod-ui
- Go to the web interface and connect the cables without adding effects
Only one side get connected, as per the image:
moreover, I can’t manually connect from qJackctl.
Here is the version i use:
zyncoder: master (c13d120)
zynthian-ui: master (50f785e)
zynthian-sys: master (eb86648)
zynthian-data: master (40dd1f1)
zynthian-webconf: master (5afcfd5)
Cheers,
Claude
