Hi everybody,
after solving a Windows-Etcher-problem I could burn my new SD with the latest image.
I did an update and reboot and edited my parameters
Hardware/Kit/Custom
Hardware/Audio/Select/Behringer UCA222
Hardware/Display/Waveshare 4C GPIO only
(in my old Image it was “Waveshare4 GPIO only” without the charakter “a” or “c”)
Hardware/Wiring/Dummies
with several reboots.
But now i have a white screen and I don hear any sound.
What am I doing wrong?
Hi wyleu,
yes.
– Logs begin at Fri 2021-03-12 11:25:06 GMT. –
Mar 12 11:46:37 zynthian startx[3416]: at http://wiki.x.org
Mar 12 11:46:37 zynthian startx[3416]: for help.
Mar 12 11:46:37 zynthian startx[3416]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Mar 12 11:46:37 zynthian startx[3416]: (EE) Server terminated with error (1). Closing log file.
Mar 12 11:46:52 zynthian startx[3416]: xinit: giving up
Mar 12 11:46:52 zynthian startx[3416]: xinit: unable to connect to X server: Connection refused
Mar 12 11:46:52 zynthian startx[3416]: xinit: server error
Mar 12 11:46:52 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Mar 12 11:46:52 zynthian systemd[1]: zynthian.service: Failed with result ‘exit-code’.
Mar 12 11:46:57 zynthian systemd[1]: zynthian.service: Service RestartSec=5s expired, scheduling restart.
Mar 12 11:46:57 zynthian systemd[1]: zynthian.service: Scheduled restart job, restart counter is at 64.
Mar 12 11:46:57 zynthian systemd[1]: Stopped Zynthian User Interface.
Mar 12 11:46:57 zynthian systemd[1]: Started Zynthian User Interface.
Mar 12 11:46:58 zynthian startx[3478]: X.Org X Server 1.20.4
Mar 12 11:46:58 zynthian startx[3478]: X Protocol Version 11, Revision 0
Mar 12 11:46:58 zynthian startx[3478]: Build Operating System: Linux 4.15.0-99-generic armv8l Raspbian
Mar 12 11:46:58 zynthian startx[3478]: Current Operating System: Linux zynthian 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l
Mar 12 11:46:58 zynthian startx[3478]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:37:27:E0 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Mar 12 11:46:58 zynthian startx[3478]: Build Date: 07 July 2020 09:38:51PM
Mar 12 11:46:58 zynthian startx[3478]: xorg-server 2:1.20.4-1+rpt2 (Debian -- Support)
Mar 12 11:46:58 zynthian startx[3478]: Current version of pixman: 0.36.0
Mar 12 11:46:58 zynthian startx[3478]: Before reporting problems, check http://wiki.x.org
Mar 12 11:46:58 zynthian startx[3478]: to make sure that you have the latest version.
Mar 12 11:46:58 zynthian startx[3478]: Markers: (–) probed, () from config file, (==) default setting,
Mar 12 11:46:58 zynthian startx[3478]: (++) from command line, (!!) notice, (II) informational,
Mar 12 11:46:58 zynthian startx[3478]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Mar 12 11:46:58 zynthian startx[3478]: (==) Log file: “/var/log/Xorg.0.log”, Time: Fri Mar 12 11:46:58 2021
Mar 12 11:46:58 zynthian startx[3478]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Mar 12 11:46:58 zynthian startx[3478]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Mar 12 11:46:58 zynthian startx[3478]: (EE)
Mar 12 11:46:58 zynthian startx[3478]: Fatal server error:
Mar 12 11:46:58 zynthian startx[3478]: (EE) no screens found(EE)
Mar 12 11:46:58 zynthian startx[3478]: Please consult the The X.Org Foundation support
Mar 12 11:46:58 zynthian startx[3478]: at http://wiki.x.org
Mar 12 11:46:58 zynthian startx[3478]: for help.
Mar 12 11:46:58 zynthian startx[3478]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Mar 12 11:46:58 zynthian startx[3478]: (EE) Server terminated with error (1). Closing log file.
Mar 12 11:47:13 zynthian startx[3478]: xinit: giving up
Mar 12 11:47:13 zynthian startx[3478]: xinit: unable to connect to X server: Connection refused
Mar 12 11:47:13 zynthian startx[3478]: xinit: server error
Mar 12 11:47:13 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Mar 12 11:47:13 zynthian systemd[1]: zynthian.service: Failed with result ‘exit-code’.
Mar 12 11:47:18 zynthian systemd[1]: zynthian.service: Service RestartSec=5s expired, scheduling restart.
Mar 12 11:47:18 zynthian systemd[1]: zynthian.service: Scheduled restart job, restart counter is at 65.
Mar 12 11:47:18 zynthian systemd[1]: Stopped Zynthian User Interface.
Mar 12 11:47:18 zynthian systemd[1]: Started Zynthian User Interface.
Mar 12 11:47:18 zynthian startx[3512]: X.Org X Server 1.20.4
Mar 12 11:47:18 zynthian startx[3512]: X Protocol Version 11, Revision 0
Mar 12 11:47:18 zynthian startx[3512]: Build Operating System: Linux 4.15.0-99-generic armv8l Raspbian
Mar 12 11:47:18 zynthian startx[3512]: Current Operating System: Linux zynthian 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l
Mar 12 11:47:18 zynthian startx[3512]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:37:27:E0 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Mar 12 11:47:18 zynthian startx[3512]: Build Date: 07 July 2020 09:38:51PM
Mar 12 11:47:18 zynthian startx[3512]: xorg-server 2:1.20.4-1+rpt2 (Debian -- Support)
Mar 12 11:47:18 zynthian startx[3512]: Current version of pixman: 0.36.0
Mar 12 11:47:18 zynthian startx[3512]: Before reporting problems, check http://wiki.x.org
Mar 12 11:47:18 zynthian startx[3512]: to make sure that you have the latest version.
Mar 12 11:47:18 zynthian startx[3512]: Markers: (–) probed, () from config file, (==) default setting,
Mar 12 11:47:18 zynthian startx[3512]: (++) from command line, (!!) notice, (II) informational,
Mar 12 11:47:18 zynthian startx[3512]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Mar 12 11:47:18 zynthian startx[3512]: (==) Log file: “/var/log/Xorg.0.log”, Time: Fri Mar 12 11:47:18 2021
Mar 12 11:47:18 zynthian startx[3512]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Mar 12 11:47:18 zynthian startx[3512]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Mar 12 11:47:18 zynthian startx[3512]: (EE)
Mar 12 11:47:18 zynthian startx[3512]: Fatal server error:
Mar 12 11:47:18 zynthian startx[3512]: (EE) no screens found(EE)
Mar 12 11:47:18 zynthian startx[3512]: Please consult the The X.Org Foundation support
Mar 12 11:47:18 zynthian startx[3512]: at http://wiki.x.org
Mar 12 11:47:18 zynthian startx[3512]: for help.
Mar 12 11:47:18 zynthian startx[3512]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Mar 12 11:47:18 zynthian startx[3512]: (EE) Server terminated with error (1). Closing log file.
Mar 12 11:47:33 zynthian startx[3512]: xinit: giving up
Mar 12 11:47:33 zynthian startx[3512]: xinit: unable to connect to X server: Connection refused
Mar 12 11:47:33 zynthian startx[3512]: xinit: server error
Mar 12 11:47:33 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Mar 12 11:47:33 zynthian systemd[1]: zynthian.service: Failed with result ‘exit-code’.
Mar 12 11:47:38 zynthian systemd[1]: zynthian.service: Service RestartSec=5s expired, scheduling restart.
Mar 12 11:47:38 zynthian systemd[1]: zynthian.service: Scheduled restart job, restart counter is at 66.
Mar 12 11:47:38 zynthian systemd[1]: Stopped Zynthian User Interface.
Mar 12 11:47:38 zynthian systemd[1]: Started Zynthian User Interface.
Mar 12 11:47:38 zynthian startx[3547]: X.Org X Server 1.20.4
Mar 12 11:47:38 zynthian startx[3547]: X Protocol Version 11, Revision 0
Mar 12 11:47:38 zynthian startx[3547]: Build Operating System: Linux 4.15.0-99-generic armv8l Raspbian
Mar 12 11:47:38 zynthian startx[3547]: Current Operating System: Linux zynthian 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l
Mar 12 11:47:38 zynthian startx[3547]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:37:27:E0 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Mar 12 11:47:38 zynthian startx[3547]: Build Date: 07 July 2020 09:38:51PM
Mar 12 11:47:38 zynthian startx[3547]: xorg-server 2:1.20.4-1+rpt2 (Debian -- Support)
Mar 12 11:47:38 zynthian startx[3547]: Current version of pixman: 0.36.0
Mar 12 11:47:38 zynthian startx[3547]: Before reporting problems, check http://wiki.x.org
Mar 12 11:47:38 zynthian startx[3547]: to make sure that you have the latest version.
Mar 12 11:47:38 zynthian startx[3547]: Markers: (–) probed, (**) from config file, (==) default setting,
Mar 12 11:47:38 zynthian startx[3547]: (++) from command line, (!!) notice, (II) informational,
Mar 12 11:47:38 zynthian startx[3547]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Mar 12 11:47:38 zynthian startx[3547]: (==) Log file: “/var/log/Xorg.0.log”, Time: Fri Mar 12 11:47:38 2021
Mar 12 11:47:38 zynthian startx[3547]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Mar 12 11:47:38 zynthian startx[3547]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Mar 12 11:47:38 zynthian startx[3547]: (EE)
Mar 12 11:47:38 zynthian startx[3547]: Fatal server error:
Mar 12 11:47:38 zynthian startx[3547]: (EE) no screens found(EE)
Mar 12 11:47:38 zynthian startx[3547]: Please consult the The X.Org Foundation support
Mar 12 11:47:38 zynthian startx[3547]: at http://wiki.x.org
Mar 12 11:47:38 zynthian startx[3547]: for help.
Mar 12 11:47:38 zynthian startx[3547]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Mar 12 11:47:38 zynthian startx[3547]: (EE) Server terminated with error (1). Closing log file.
also you can from the webconf access to the terminal and give us some more informations:
- output of
cat /var/log/Xorg/Xorg.0.log
Xorg display server logs - output of
dmesg
system startup logs
There’s something wrong in your display configuration
The settings of the audio jackd Options command line would be interesting as well just to confirm what we are asking jack to set up. . .
Select advanced to get the full gore . . .
You could try with other vaweshare 4 option in webconf
did that. same result.
If it’s not too much fuss to set up try dummies display and come in via vnc. . . .
That will at least show if the machine flies. This might be a little bit more contrived than it may first appear but it is one way of getting sight of a machine that is a bit pawllie. . .
don know, how to do it.
Well my behringer 202 is working ok . . ., I’m strongly suspecting the screen …
RealVNC download the viewer onto your PC or laptop, this is where the vnc screen will be displayed.
https://www.realvnc.com/en/connect/download/viewer/
Then set up the zynthian end of the vnc server which the viewer looks at . . .
You then start vncviewer on your host and point it at zynthian.local and if that doesn’t work (it frequently doesnt in PC’s and android environments ) get the ipaddress of the zynth and use that.
in the webconf, under system menu, there’s “terminal”
from the command line there type:
lsmod
that will list the kernel modules -
vcdbg log msg
that will show if there is some ovarlay (hardware configuration at boot time) problem
… I will soon go back to work …
yes, me too.
I will insert the old sd and copy the entries for display.
It will take some time, I will be back after that.
thank you for helping
you’re not using the latest zynthian version, (Zynthian-U commit e9e503f -in your first screenshot- is from september 2020). Do a software update.
I loaded the actual stable version from the zynthian page
than i updated
and tried to start.
Where do I find the “latest version”?
Might be worth trying a software update.
