I have problem that I can’t connect to MOD-UI. Administration works great but when point browser to address http://zynthian.local:8888 nothing happen even if I change to local ip address instead of zynthian.local. Can you help me with that? I’m using actual version.
You first have to choose the MOD-Engine.
Sorry for noob question but where I have to choose the MOD-Engine?
Just take a look at: http://wiki.zynthian.org/index.php/Zynthian_UI_Users_Guide
At Engine List
you can see the last engine is named “MOD-UI Plugin host”. If you start this engine MOD-UI is started in background and you can enter the web interface (see http://wiki.zynthian.org/index.php/MOD_Users_Guide).
Regards, Holger
Thank for your answer. Maybe it’s important to say that I’m trying to run Zythian in headless mode. So next steps what I need to is login to Raspberry through SSH and start UI with this command: systemctl start zynthian
Yes, this is really important…
does not help, because it starts AFAIK the GUI on the display… not relly helpful. You may try:
systemctl start jack2
systemctl start mod-host
systemctl start mod-ui
Zynthian itself is not build for headless mode.
Regards, Holger
