I have compiled Cardinal and also patched it to enable some more advanced OSC interface. Our friend falkTX who maintains Cardinal is not keen on some of these changes and they are not robust yet so I submitted a PR upstream. I am using Cardinal (outside of Zynthian) on RPi4 as a PoC for a project. It mostly works on a 64-bit RPi. That project may inform our consideration of whether Cardinal fits well in Zynthian.
Unfortunately I havenāt been playing with Zynthian recently either, but I do have a recurring half-idea for a Cardinal-running module as well:
- Raspberry pi (or orange pi) with Wifi, running a minimal system with buildroot, jack, jalv or modhost, and Cardinal
- Custom āhatā PCB with an I2S audio DAC, and a RP2040 (or similar) running a CV-to-MIDI (over serial on a high baud rate) and one or two push encoders (also through MIDI)
- Mini I2C screen, e.g. one of those cheap OLED displays
This should give 2x audio in, 2x audio out, 2-4 CV in at reasonable almost-audio speed, and no ridiculous costs in components. Well, beyond the time spent creating the schematic, PCB, and getting the software to play together ![]()
Any updates on this?
I was recently discussing this with someone who wanted to use some of the Mutable Instruments equivalent modules in Zynthian.
Hey @riban - do you happen to know if those Pull Requests were accepted?
The PR was rejected. Upstream is not interested in making Cardinal work headless. They consider it as a GUI application. I have tried to abstract the core (non-gui) elements but it is challenging because of the heavy GUI integration. (That was for another project but the learning does support upstream preference to only support GUI use.)
I am still sceptical how well this fits into zynthian. We could add it as a special engine (like mod-ui) with limited zynthian UI integration and depend on native web-based configuration. This requires significant effort so, before embarking on such a task, we should test the validity of adding it. (I am not a fan of mod-ui in zynthian because it doesnāt offer much more than a pretty UI over what zynthian offers natively.) We donāt want to add the burden of supporting a fork if there is limited benefit to just a few users.
Pity. It would have been nice if patches could be loaded into it a la PureData.
Speaking of PD, I see that at least some of the modules we were discussion are available as PD externalsā¦
Iām working on a PD version of Mutable Instruments Plaits and will post it when completed.
Hi @rosum,
I did this once with 0-coast, and the possibility to change the patch with virtual cables on the fly. It was quite functional, but a bit CPU heavy in the end.
If youād need help with the zynthian integration (json file to get the controls usable in the UI), donāt hesitate ā¦
Another approach would be to use the DSP code and build a lv2 plugin for this using the DISTRHO framework. Then you could have multiple instances of plaits running in zynthian. If Iād only had the time for this ⦠![]()
Good luck
BTW - I didnāt want to capture this topicā¦
Oh, thatās a good idea. Iād really like the physical modelling modules like Elements and Rings as lv2 plugins.
Itās just a pity I hate C++ with the heat of a thousand fiery suns. ![]()
That is really hilarious @Kirtai ![]()
What is the origin of such uncompromising hate, for the good olā father of all current programming languages? Just curious: you certainly have well-founded reasons based on disappointing experiences!
Most of my programming has been done in Lisp and Smalltalk ![]()
After a short research I found i.e. this lv2 mutable instruments clone source:
I tried to compile on my desktop. After a second make call it compiles, the lv2 plugins showed up in carla, but I didnāt manage to get any sound, i.e. by using the āpoly macro oscā.
Also, because of being a eurorack module it has a lot of CV in- and outputs.
Another idea would be to compile the puredata libraries of the MI clones on zynthian, and then use pd to get access to them.
If Iād had the time ⦠a pityā¦
Is it, perhaps, becoming a little rusty in itās old age. . . ?
Python is as far as a disinterested user should go.
Down there be dragons⦠& PD Peopleā¦
Good isnāt it?
No love for ZZT-OOP?
EDIT: I was joking, but then I realized my introduction to making electronic music was trying to make PC speaker covers of Metallica riffs in ZZT-OOP when I was like 11. Itās been downhill from there.
Has there been any new evolvement about Cardinal LV2 plugin?
I saw the install intructions
from here * Starting the standalone bin/Cardinal starts up, and opens up UDP port 8222 (just like the āofficialā installation on MOD DUO does).
then would it be possible to access Cardinal GUI via web-browser?
I still havenāt started a single web instance of a plugin yet, I am still experimenting
with the basic Zynthian functionalitiesā¦
ā late edit ā snipped out a lot on irrelevant opinionsā
PS: I started Web-GUI for Osiris Synth and itās working marvels!
If anyone can get Cardinal Web-GUI working⦠Iāll have to try⦠just not
ready yet⦠still have to figure out a bunch of other stuff
(and do a BUP, with ok recall-reinstall on a separate sd)
FWIW I downloaded the aarch64 version 24.12 the other day and copied the 3 LV2 files from the extracted archive into the Zynthian LV2 folder. Other than enabling the plugins using the webconf, no other work required.
Itās probably quite cpu intensive, but you can load the web-gui uisng the vnc-engine view.
At least one of the demo patches generates noise, so I assume its working.
Hello everyone. Iām using Cardinal inside Zynthian 5.1 Oram, both as synth and as FX. I mapped many params with āHost Paramsā module and it works well. Is there a way to assign a label for each param, other than āParameter 1ā, so they can be displayed inside the Zynthian display? I tried with the .ttl with no success. Thanks.
Modifying TTL is the way. Could you explain the steps you followed? Perhaps you missed something important.
BTW, could you share the compiled cardinal LV2-plugin for zynthian?
Is it availabel for arm64 or did you compile it?
Hellooo!
I installed the version compiled for arm64 from their github repo and it works well: Releases Ā· DISTRHO/Cardinal Ā· GitHub
I created a script that saves the .ttl files for the preset, starting from a .vcv file (like a custom_cardinal.preset.lv2 folder that contains custom_cardinal.ttl and manifest.ttl)
The preset works and all params are mapped and working. But the names or labels are not showing.
AFAIK it seems that the names are defined into the .ttl plugin file which is found inside the plugin folder (like /zynthian/zynthian-plugins/lv2/CardinalFX.lv2/CardinalFX.ttl for the FX version). If I change the names here it works, but it gives these params names to each preset.
I wanted to have custom params names for each preset, but it does not seem possible.
Now Iām exploring another way: creating a C++ wrapper for Cardinal, a custom plugin that embeds Cardinal and maps params with custom labels. Iāll let you know if it works.
I finally made it! The C++ wrapper for Cardinal LV2 works fine.
I made a web app that lets you load a Cardinal .vcv patch and update parameters label, value, range and type (integer, float, list of parameters name=>value). Then you can export a zip file with 4 different folders:
A preset folder for Cardinal, with manifest.ttl and preset.ttl, with custom paramaters values (but no custom names/labels)
A custom plugin wrapper for Cardinal, that replaces default Cardinal plugin.ttl definition with custom parameters names/labels (but you can have only one running instance with same parameters names/labels, so you can change preset and patches but not the names/labels)
This is the real solution: a custom C++ plugin wrapper for Cardinal, with its own parameters names/labels. You can create many wrappers that show up as new plugins, each one with its own presets. Each wrapper uses an instance of the main Cardinal plugin
A preset folder for the custom Cardinal plugin wrapper, with manifest.ttl and preset.ttl
You can find the free web app here: Tools ā Real Time Webcam Tracking Midi Interfaces (scroll down to Cardinal LV2 Wrapper and Preset creator for Zynthian).
The cpp file and compile command could probably be improved. If you are a c++ expert and you want to contribute, please let me know.
