Welcome!
Absolutely.
The devil is in the detail. How many encoders and how are you going to mount it in your stage rig…?
I’ve got a Roland rc-300, or rather Ive lent it to a friend of mine. I used to find it a pain to have to bend down to foot level to adjust things.
You can most certainly build something. Personally I use Blue Pills, for which you need a programmer thingy, the ST-LINK which connects to the 4 wires on the Pill to allow you to program it. @riban has a few devices that are similarly configured, and we’ve documented the process of getting MIDI out over the USB connection. This is very useful as it also Powers the ‘device’ with just one wire and that is an excellent solution to a problem most people don’t consider until they’ve built it. How to power it.
From the encoder perspective I would use these …
It’s all comms over i2c and they have rgb led’s in them. It will save you hours of debugging hardware.
Start drawing panels!
And add a device ctrl driver to the zynthian so it does what you want it to do…
