I’m not sure if this was already mentioned somewhere and I missed it, but on the new stable release when you load a preset in Osirus or OsTIrus the Zynthian parameter contols all start at their minimum (fully ccw) rather than reflecting the actual values loaded from the preset. This also means that the actual loaded value jumps to the Zynthian control’s value as soon as you make a change. Sounds fantastic and works well otherwise, though, just like the hardware.
