I have been using a headless system updated to the latest Oram staging for some time. I’m trying to set up a second system identical to the first. Having some problems with font sizes being different and mouse clicks behaving differently. First thing I’ve noticed is that “Dummies” seems to have disappeared and replaced by “Custom” on the existing system. The Wiki version I’m seeing still has references to “Dummies”. Has “Dummies” been depreciated and and now automatically replaced by “Custom” when encountered? Could this explain the different font sizes and mouse behavior between the two systems even though all webconf settings seem to be the same? Also on the existing system I see “Custom” in the kit selection and “Mini V2” in Wiring section. Is this expected behavior. I seem to remember them all having been set to “Dummies” at some earlier time.
ps - Please disregard the above around “Dummies”; I can’t seem to delete it. It’s been a while since I did any configuring on my base system. I now see “Custom” in “Kit”, “Mini V2” in “Wiring” and “Dummies” in webconf. If I click on “Dummies” in webconf it takes me to “Wiring” where “MiniV2” shows up. Is this just a bug that should be reported? Font size problem and mouse cursor size are probably unrelated questions.
(FIX) Wrong display selected. Don’t know why it caused a problem on one box and not the other. Still have a problem where mouse click is not detected for certain operations but I’ll dig into that separately. Still can’t find “DUMMIES” in “Wiring” but I’ll log a bug about that.
