I ran the update software command from the web interface, and now I get an error screen upon boot. This is a V2 unit, never had an issue before. zynthian_update.txt (3.8 KB)
The last line is “Running Flag Actions from ‘/zynthian/zynthian-sys/scripts/update_zynthian.sh’…”
I can ssh into the unit and do
systemctl stop zynthian
systemctl start zynthian
but it does not resolve the problem. I do not see a zynthian_update_sys.sh anywhere.
I just stopped zynthian using the ssh interface, and ran update_zynthian.sh from the terminal, and I do see one error in the trace:
Updating zynthian-sys …
Already up to date.
Executing custom update recipes …
Executing /zynthian/zynthian-sys/scripts/recipes.update.buster/00_install_packages.sh …
raspberrypi-sys-mods was already set on hold.
Hit:1 Index of /debian buster InRelease
Hit:2 Index of /raspbian buster InRelease
Hit:3 http://www.deb-multimedia.org buster InRelease
Error: GDBus.Error:org.freedesktop.systemd1.UnitMasked: Unit packagekit.service is masked.
root@zynthian:/home/pi/zynthian-ui/zyngui# apt install python3-evdev
Reading package lists... Done
Building dependency tree
Reading state information... Done
Suggested packages:
python-evdev-doc
The following NEW packages will be installed:
python3-evdev
0 upgraded, 1 newly installed, 0 to remove and 240 not upgraded.
Need to get 35.3 kB of archives.
After this operation, 194 kB of additional disk space will be used.
Get:1 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf python3-evdev armhf 1.1.2+dfsg-1+b1 [35.3 kB
Fetched 35.3 kB in 1s (24.5 kB/s
Selecting previously unselected package python3-evdev.
(Reading database ... 102717 files and directories currently installed.)
Preparing to unpack .../python3-evdev_1.1.2+dfsg-1+b1_armhf.deb ...
Unpacking python3-evdev (1.1.2+dfsg-1+b1) ...
Setting up python3-evdev (1.1.2+dfsg-1+b1) ...
I don’t know what happened that meant evdev wasn’t installed as it is needed for the calibration, it might mean other stuff has gone awry. I’d recommend backing up snapshots and stuff and starting again from a recent image.
