Hi.I made gpio midi in circuit with 6n138
and…no work.Any sugestion ? Tks
Well this isn’t much of a suggestion, but I did find a SparkFun midi shield that used a 6n138 and the schematic differs in a couple-few ways:
So I thought that might help you.
Differences I noticed were use of Zener diode not ‘regular’, no 40K resistor, much smaller 220 ohm instead of 4K ‘pullup’ resistor.
I wanted to find the Zynthian schematic as a pdf but couldn’t, and don’t know if it uses a 6n138 anyway.
Here’s an interesting thread on midi circuits:
And another
Can you provide a bit more info on what it is doing to make you say ‘no work’?
Thanks for the reply. It works perfectly. My synthesizer was the problem. … settings for midi out
[image]
