and the build tries to start up but just reboots every second or so on startup even with the encoder board disconnected. Can’t ssh onto it, can’t see the webconf . …
Well I’ve finally got zynthian-nord up and going again… Didn’t have much joy with the latest build and ended up using the torrent for v2 kit, which is old enough that the current version on the wiki doesn’t have a software update on the webconf and seemed to freeze on running it from the gui front end… Had to run the update script from an ssh shell in the end which worked in the end…
