How do I delete preset pedalboards on mod-ui?
Hey,
Zynthinan comes with lots of preset ones and sevral I don’t want anymore.
Thanks,
You can delete it by hand, accessing with SSH/SFTP.
@mheidt, perhaps we can open a task (low priority) for adding a “system mode” to the library tabs that allow to manage the “system” presets, soundfonts, etc.
Also, currently MOD-UI pedalboards are not covered by the webconf and it should be covered. Perhaps it should be treated as “presets” … in that case, a simple soft link could do the trick. Let me see …
The same symbolic link trick should work for system presets as well
Can you provide the paths where all this goodness lies in?
You should take a look to this 2 directories:
  • /zynthian/zynthian-data => factory data, like presets, soundfonts, etc.
  • /zynthian/zynthian-my-data => user data
