I would like to know how to install plugins in MOD-UI.
I assume that it’s done through the terminal since you cant use the MOD web service to download them. the main thing I’m interested in is the control voltage plugins
You can use the web interface on Zynthian. I’ve never tried downloading a plugin as it has seemingly hundreds installed.
Current zynthian SD-image include AMS plugins, that i think is what you are looking for. You don’t need to do nothing, simply select from the MOD-UI palette. This is the list of AMS plugins:
AMS Advanced Envelope
Envelope
http://github.com/blablack/ams-lv2/advenv -
AMS Amp
Amplifier
http://github.com/blablack/ams-lv2/amp -
AMS Analog Driver - 2 Outputs
Spectral
http://github.com/blablack/ams-lv2/ad_2 -
AMS Analog Driver - 4 Outputs
Spectral
http://github.com/blablack/ams-lv2/ad_4 -
AMS Analog Driver - 6 Outputs
Spectral
http://github.com/blablack/ams-lv2/ad_6 -
AMS Analog Memory
Delay
http://github.com/blablack/ams-lv2/analogmemory -
AMS Bitgrinder
Spectral
http://github.com/blablack/ams-lv2/bitgrinder -
AMS CV Source
Utility
http://github.com/blablack/ams-lv2/cvs -
AMS Delay
Delay
http://github.com/blablack/ams-lv2/delay -
AMS Envelope
Envelope
http://github.com/blablack/ams-lv2/env -
AMS FFT Vocoder
Spectral
http://github.com/blablack/ams-lv2/fftvocoder -
AMS Hysteresis
Delay
http://github.com/blablack/ams-lv2/hysteresis -
AMS Inv
Utility
http://github.com/blablack/ams-lv2/inv -
AMS Mixer 2 channels
Utility
http://github.com/blablack/ams-lv2/mixer_2ch -
AMS Mixer 4 channels
Utility
http://github.com/blablack/ams-lv2/mixer_4ch -
AMS Mixer 8 channels
Utility
http://github.com/blablack/ams-lv2/mixer_8ch -
AMS Percussive Envelope
Envelope
http://github.com/blablack/ams-lv2/percussiveenv -
AMS Ring Modulator
Amplifier
http://github.com/blablack/ams-lv2/ringmodulator -
AMS Sample&Hold
Delay
http://github.com/blablack/ams-lv2/samplehold -
AMS Sequencer - 12 Steps
Utility
http://github.com/blablack/ams-lv2/seq_12 -
AMS Sequencer - 16 Steps
Utility
http://github.com/blablack/ams-lv2/seq_16 -
AMS Sequencer - 24 Steps
Utility
http://github.com/blablack/ams-lv2/seq_24 -
AMS Sequencer - 32 Steps
Utility
http://github.com/blablack/ams-lv2/seq_32 -
AMS Sequencer - 8 Steps
Utility
http://github.com/blablack/ams-lv2/seq_8 -
AMS Slew Limiter
Delay
http://github.com/blablack/ams-lv2/slew -
AMS Stereo Mixer 2 channels
Utility
http://github.com/blablack/ams-lv2/stereomixer_2ch -
AMS Stereo Mixer 4 channels
Utility
http://github.com/blablack/ams-lv2/stereomixer_4ch -
AMS Stereo Mixer 8 channels
Utility
http://github.com/blablack/ams-lv2/stereomixer_8ch -
AMS VC Delay
Delay
http://github.com/blablack/ams-lv2/vcdelay -
AMS VC Double Decay
Delay
http://github.com/blablack/ams-lv2/vcdoubledecay -
AMS VC Envelope
Envelope
http://github.com/blablack/ams-lv2/vcenv -
AMS VC Envelope II
Envelope
http://github.com/blablack/ams-lv2/vcenvii -
AMS VC Panning
Spatial
http://github.com/blablack/ams-lv2/vcpanning -
AMS VC Switch
Amplifier
http://github.com/blablack/ams-lv2/vcswitch -
AMS VCA Exp
Amplifier
http://github.com/blablack/ams-lv2/vcaexp -
AMS VCA Lin
Amplifier
http://github.com/blablack/ams-lv2/vcalin -
AMS VCF
Spectral
Probably, there are more plugins that can be useful in a modular setup.
Enjoy … and send somefeedback!!
well I’m still not sure about what you’re saying because I enabled the AMS plugins in the effects Screenshot (38)|690x337
but I still don’t see them in the MOD-UI.
I also don’t know what you mean by:
thanks for helping
The webconf LV-2 Plugin configuration only affects which plugins appear in the Zynthian’s layers lists and does not affect MOD-UI. My MOD-UI shows a different result to yours:
What version of Zynthian firmware are you using? (You can post a picture of your webconf home page with this information.)
