Interesting little attempt of zynthian-amp4.local with a
Guitar to USB lead.
plugged in the new thingie…
aplay -l
^Croot@zynthian-amp4:~# aplay -l
card 1: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
Subdevices: 4/4
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
card 2: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 4/4
card 3: sndrpihifiberry [snd_rpi_hifiberry_dacplus], device 0: HiFiBerry DAC+ HiFi pcm512x-hifi-0 [HiFiBerry DAC+ HiFi pcm512x-hifi-0]
Subdevices: 0/1
card 6: Device [USB Audio Device], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Build a new audio effect layer …
so using alsa_in
alsa_in -j “USBGuitar” -d hw:CARD=Device,DEV=0 -r 44100 -p 256
The new source appears in patchage but un connected …
so connect it …
Well it kind of works but not great . . .
amixer -D “hw:CARD=Device” controls
numid=10,iface=CARD,name=‘Keep Interface’
numid=3,iface=MIXER,name=‘Mic Playback Switch’
numid=4,iface=MIXER,name=‘Mic Playback Volume’
numid=7,iface=MIXER,name=‘Mic Capture Switch’
numid=8,iface=MIXER,name=‘Mic Capture Volume’
numid=9,iface=MIXER,name=‘Auto Gain Control’
numid=5,iface=MIXER,name=‘Speaker Playback Switch’
numid=6,iface=MIXER,name=‘Speaker Playback Volume’
numid=2,iface=PCM,name=‘Capture Channel Map’
numid=1,iface=PCM,name=‘Playback Channel Map’
Any thoughts . . .? Presumably we are hearing two slightly different timing clocks at work; the hifiberry and the USB infrastructure clock…?
