When there is no name, it fails like this:
just generate a default name or number.
Hi @mheidt!
āMaster MIDI Bank & Program change for snapshot loadingā is almost ready. As soon as we solve the problems with the webconf tool , i will upload the changes ![]()
Also, iāve added a new config variable and would be nice to have it in the webconf tool. Itās for selecting the Bank change āmodeā. Itās name is:
ZYNTHIAN_MASTER_MIDI_BANK_CHANGE_CCNUM
And 2 values are possible:
Perhaps a 3rd option should be added for allowing using both and have 128x128 banks.
A selection box with those two values?
how did you create those snapshots? ssh?
Because a dash (-) is mandatory between number and name.
Nevertheless I will change something, so that the dash is not mandatory.
Exactly!!!
āLSBā and āMSBā
No, i used the Zynthian UI ![]()
If the name is optional, the dash too ![]()
I canāt reproduce it locally on my pcā¦no zynthian available right now.
Could you show me your
find .
from /snapshots?
root@zynthian:/zynthian/zynthian-my-data/snapshots# find .
./00001-Mampon
./00001-Mampon/002.zss
./00008
./00008/001.zss
./00002-Bank2
./00007-Bank7
./00007-Bank7/001-pitos.zss
./00007-Bank7/002.zss
checkout branch snapshotWebConfFix
Only the fix, not the new LSB/MSB feature
Thanks @mheidt! It works like a charm now!
Iāve uploaded the changes for the Master MIDI remote control commands, implemented according to the specification discussed in this thread. You can āupdate softwareā from the āadmin menuā ![]()
Currently āBank Change Modeā is configured by default to LSB. Itās possible to change it to MSB by editing the config file:
/zynthian/zynthian-sys/scripts/zynthian_envars.sh
Yes, iāve to move this config file to a better place ![]()
If you have any doubt, please, ask me. I hope to make a little āstopā in development and spend some time improving the user guide, etc.
Next step: Master Volume ![]()
checkout branch ZYNTHIAN_MASTER_MIDI_BANK_CHANGE_CCNUM.
I had to make changes to config_block as well.
I am storing the values as string like ā32āā¦int values not supportedā¦
[FORGET THIS COMMENT! I was using an older version
There is a little error in webconf->snapshot. When deleting the name of a snapshot, a slash is left before the ā.zssā, and the the string ā.zssā appears as name:
BTW, could you give a try to the new feature?
OK! Tested and merged!
Thanks a lot, Markus!
I canāt reproduce the error. Actually this is the bug I had when I fixed your bug. It was never empty for me, but I always saw the extension.
Forget the error. I was using an older version. Sorry
