if yes, that’s ok !
Blank screen with ip address happens when jack isn’t started
you can try to debug that through ssh:
once logged in: systemctl stop jack2 /usr/local/bin/jackd -P 70 -t 2000 -s -d alsa -d hw:ALSA -r 44100 -p 512 -n 3 -X raw
(these are default parameters for the onboard audio)
Check also that in /boot/config.txt following lines are here: dtparam=audio=on audio_pwm_mode=2
Just flashed to 2020-05-27 and I didn’t experience any of the issues I got with 2020-5-29. Exact same config.
Kit = Custom
Audio = Rbpi On-Board Audio.
Setup was straight forward.
I’ll go back to 2020-05-29 again for a moment and take a screen shot of the audio settings in v27 to compare them to v29. I will also SSH in and do that check you mentioned.
I can confirm there’s something wrong with audio. I’ve rebooted zynthian to see if assignment of midi cc for controlling sound engines output level are stored in snapshots, but zynthian gave me the error screen.
Without having changed anything in audio configuration, now launching from ssh: /usr/local/bin/jackd -P 70 -t 2000 -d alsa -d hw:U192k -r 48000 -p 256 -n 3 -s -S -X raw
(arguments for UMC404 HD)gives me: ALSA: no playback configurations available (Invalid argument) ALSA: cannot configure capture channel
I flashed back to 2020-05-29 and like before I only get as far as the Splash Screen / Error. I’ve also ran those checks you ask me to and the Boot/config is fine but after I stop Jack and run the next command I get the following error.
Hi Wyleu.
A tiny bit of tin foil can help, but depending on your screen it might need to be more like a chunky blob rather than a pin point. Capacitive Screen’s just need it to be a little bit wider than a point.
so i rebooted zynthian => still the error, and my card isnt’ shown anymore when doing an aplay -l command.
unplugged/replugged the usb audio interface, and it’s up again, ui start
I’ve labeled the 2020-05-27 image as “Buster RC2”. It seems to be working quite nicely. Please, keep testing this image and report problems on this thread:
I just updated the wiki links too …
If somebody find a link to Buster RC-1 that should be changed, please, notify me, or simply change it if you have access
I wouldn’t use that one cause it contains two bugs already.
One related to AudioInjector and the other in this new MidiEngine area.
And I would wait for the next iteration of stepseq.
Why don’t we plan to use 07-01 and try to not commit major changes in the week before that date?
So… which version to use? Wiki still pointing to RC2. How about we merge zynstep and create RC3 (after a few days of testing the merge went well)? Then as @mheidt days, put in a feature freeze.
Which one would be the most stable version to use with a Pi4¹ at the moment?
Actually in the end I don’t really care about latest features but serious stability as I’d like to take mine out for a little gig on tuesday
¹edit: Current setup is v3 kit with DAC+ADC Pro, but Pi4.
