Hi @zynthianers !
As requested by @Baggypants on this feature request:
opened 07:57AM - 02 Jul 20 UTC
Is your feature request related to a problem? Please describe.
engines from KXStudio appear to be more performant. E.g. OB-Xd from KXStudio...
enhancement
I’ve modified the SD image build scripts for using the KXStudio repository wherever it’s possible. By using packages from this repository we have several advantages:
Improved performance for some packages, like OBX-d, as falkTX (the guy who created the repo) has a lot of experience building packages (ARM platform included).
Stable versions.
Easy and quicker updates for engine and plugins
Reduced build time (about 2 hours less!!)
This is the first successfully built image with the new settings:
https://os.zynthian.org/2020-07-03-zynthianos-buster-lite-armhf-1.0.0.zip
I’m not sure if it’s fully functional. We have to test it carefully …
Would you happen to know what version of kernel this is using?
I tested raspberry pi os buster and was able to get it to usb3/SSD boot on a pi 4, but I fear the zynthian kernal is stopping me from doing the same on zynthian.
This may hold the key !
Zynthian kernel is the same included with the official RaspberryPi OS Buster.
wyleu
July 4, 2020, 6:27pm
5
Goes off to sharpen a dungeon…
Doesn’t work for me unfortunately.
The only way I’m able to boot into the Zynthian UI is if I set my sound card to Dummy Device.
Soon as I set it to what it’s supposed to be, “Rbpi On-board Audio” I get stuck on the splash screen displaying the IP address to WebConfig.
James
Can’t somebody reproduce the issue with “RBPi On-Board Audio” ?
The Software/Repositories tab in the WebConfig also doesn’t load at all for me.
I just get a “500: Internal Server Error”. Every other page loads fine.
Kind regards
James
riban
July 5, 2020, 3:57pm
9
@Tubbritt do you have anything plugged into USB? If so, will you try with it unplugged?
Hello.
There’s nothing connected. Just LAN and Power that’s all.
Kind regards
James.
wyleu
July 5, 2020, 4:39pm
11
Sive seen the same problem with on board audio. It worked previously using on board. I now select dummies
Please, could you send the webconf logs for the error 500?
From the command line:
journalctl -u zynthian-webconf
wyleu
July 5, 2020, 5:08pm
14
– Logs begin at Thu 2019-02-14 10:11:58 GMT. –
Jul 05 18:08:27 zynthian-ceed startx[1792]: to make sure that you have the latest version.
Jul 05 18:08:27 zynthian-ceed startx[1792]: Markers: (–) probed, (**) from config file, (==) default setting,
Jul 05 18:08:27 zynthian-ceed startx[1792]: (++) from command line, (!!) notice, (II) informational,
Jul 05 18:08:27 zynthian-ceed startx[1792]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Jul 05 18:08:27 zynthian-ceed startx[1792]: (==) Log file: “/var/log/Xorg.0.log”, Time: Sun Jul 5 18:08:27 2020
Jul 05 18:08:27 zynthian-ceed startx[1792]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Jul 05 18:08:27 zynthian-ceed startx[1792]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Jul 05 18:08:28 zynthian-ceed startx[1792]: ./zynthian.sh: line 55: /sys/class/backlight/*/bl_power: No such file or directory
Jul 05 18:08:28 zynthian-ceed systemd[1]: Stopping Zynthian User Interface…
Jul 05 18:08:28 zynthian-ceed startx[1792]: Terminated
Jul 05 18:08:31 zynthian-ceed startx[1792]: PNG file: /zynthian/config/img/fb_zynthian_error_ip.png - Application must supply a known background gamma
Jul 05 18:08:31 zynthian-ceed startx[1792]: /zynthian/config/img/fb_zynthian_error_ip.png is 1366x768 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4546
Jul 05 18:08:31 zynthian-ceed startx[1792]: Zooming image by 100%…done
Jul 05 18:08:31 zynthian-ceed startx[1792]: Merging…didn’t find evidence of prior run.
Jul 05 18:08:31 zynthian-ceed startx[1792]: done
Jul 05 18:08:31 zynthian-ceed startx[1792]: Building XImage…done
From the ui-log.
Log file attached.
JamesLog File.txt (43.4 KB)
Please, send the output if this command:
cd /zynthian/zynthian-ui; git remote update origin --prune
And also, try to update the software.
wyleu
July 5, 2020, 5:36pm
17
similar problem…
UI Log
– Logs begin at Sun 2020-07-05 18:50:21 BST. –
Jul 05 18:50:41 zynthian-ceed startx[512]: Cannot connect to server socket err = No such file or directory
Jul 05 18:50:41 zynthian-ceed startx[512]: Cannot connect to server request channel
Jul 05 18:50:41 zynthian-ceed startx[512]: jack server is not running or cannot be started
Jul 05 18:50:41 zynthian-ceed startx[512]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Jul 05 18:50:41 zynthian-ceed startx[512]: libjackpeak failed to start jack client: 17
Jul 05 18:50:43 zynthian-ceed startx[512]: PNG file: /zynthian/config/img/fb_zynthian_error_ip.png - Application must supply a known background gamma
Jul 05 18:50:43 zynthian-ceed startx[512]: /zynthian/config/img/fb_zynthian_error_ip.png is 1366x768 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4546
Jul 05 18:50:43 zynthian-ceed startx[512]: Zooming image by 100%…done
Jul 05 18:50:43 zynthian-ceed startx[512]: Merging…done
Jul 05 18:50:43 zynthian-ceed startx[512]: Building XImage…done
Jul 05 18:50:50 zynthian-ceed startx[512]: Cannot connect to server socket err = No such file or directory
Jul 05 18:50:50 zynthian-ceed startx[512]: Cannot connect to server request channel
Jul 05 18:50:50 zynthian-ceed startx[512]: jack server is not running or cannot be started
Jul 05 18:50:50 zynthian-ceed startx[512]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Jul 05 18:50:50 zynthian-ceed startx[512]: libjackpeak failed to start jack client: 17
Jul 05 18:50:51 zynthian-ceed systemd[1]: zynthian.service: Stopping timed out. Terminating.
Jul 05 18:50:51 zynthian-ceed systemd[1]: zynthian.service: Control process exited, code=killed, status=15/TERM
Jul 05 18:50:51 zynthian-ceed startx[512]: xinit: connection to X server lost
Jul 05 18:50:51 zynthian-ceed startx[512]: [1B blob data]
Jul 05 18:50:51 zynthian-ceed startx[512]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Jul 05 18:50:52 zynthian-ceed startx[512]: xinit: unexpected signal 15
Jul 05 18:50:52 zynthian-ceed systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Jul 05 18:50:52 zynthian-ceed systemd[1]: zynthian.service: Failed with result ‘timeout’.
Jul 05 18:50:52 zynthian-ceed systemd[1]: Stopped Zynthian User Interface.
Jul 05 18:50:52 zynthian-ceed systemd[1]: Started Zynthian User Interface.
Jul 05 18:50:52 zynthian-ceed startx[821]: X.Org X Server 1.20.4
Jul 05 18:50:52 zynthian-ceed startx[821]: X Protocol Version 11, Revision 0
Jul 05 18:50:52 zynthian-ceed startx[821]: Build Operating System: Linux 4.15.0-48-generic armv8l Raspbian
Jul 05 18:50:52 zynthian-ceed startx[821]: Current Operating System: Linux zynthian-ceed 4.19.118-v7+ #1311 SMP Mon Apr 27 14:21:24 BST 2020 armv7l
Jul 05 18:50:52 zynthian-ceed startx[821]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=1366 bcm2708_fb.fbheight=768 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Jul 05 18:50:52 zynthian-ceed startx[821]: Build Date: 05 June 2019 12:49:54PM
Jul 05 18:50:52 zynthian-ceed startx[821]: xorg-server 2:1.20.4-1+rpt1 (https://www.debian.org/support )
Jul 05 18:50:52 zynthian-ceed startx[821]: Current version of pixman: 0.36.0
Jul 05 18:50:52 zynthian-ceed startx[821]: Before reporting problems, check http://wiki.x.org
Jul 05 18:50:52 zynthian-ceed startx[821]: to make sure that you have the latest version.
Jul 05 18:50:52 zynthian-ceed startx[821]: Markers: (–) probed, (**) from config file, (==) default setting,
Jul 05 18:50:52 zynthian-ceed startx[821]: (++) from command line, (!!) notice, (II) informational,
Jul 05 18:50:52 zynthian-ceed startx[821]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Jul 05 18:50:52 zynthian-ceed startx[821]: (==) Log file: “/var/log/Xorg.0.log”, Time: Sun Jul 5 18:50:52 2020
Jul 05 18:50:52 zynthian-ceed startx[821]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Jul 05 18:50:52 zynthian-ceed startx[821]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
After running the command I get the following.
/zynthian/config$ cd /zynthian/zynthian-ui; git remote update origin --prune
Fetching origin
fatal: unable to access ‘https://github.com/zynthian/zynthian-ui.git/ ’: Could not resolve host: github.com
error: Could not fetch origin
Tried the software update and I get the following.
Software update.txt (5.5 KB)
Still can’t access the Software/Repositories with WebConfig.
James.
Yes, totally, I think buster have renamed the alsa devices. Change the jackconfig to use hw:b1
for HDMI or hw:Headphones
for PWM
root@zynthiantouch:~# aplay -l
card 0: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
Subdevices: 3/4
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 4/4
Software / Repositories page loads fine for me so I can’t help with that, sorry.
wyleu
July 5, 2020, 7:25pm
20
@Baggypants suggestion works…
Could not resolve github.com ? is this correctly configured to reach the internet because it appears you have a DNS problem.
I’ve just clobbered my resolv.conf on the pi and it’s throwing 500 errors now. @Tubbritt I think you have internet issues. Although it would be preferable if this was caught, some people might want to use the webconfig offline!
