I have on a few occasions accidentally entered MIDI learn mode. At that point it seems I’m locked into selecting a controller. That’s inconvenient especially if there is no controller hooked up. There doesn’t seem to be a way to exit MIDI Learn mode. Is there?
Simply push back
Duh… I can’t believe I didn’t try that.
Thanks.
@Dithered42 and @jofemodo,
this happened to me so many times…fooled aroud where the solution is always at hand.
Yep! Far too easy to get in learn mode when using touch screen. We should consider how we improve the touch interface. It has been a back-burner issue for some time because it needs some clever thinking, maybe a quite different approach. Now that I have a touchscreen attached I may start to consider this.
Did somebody investigate already, if buster allows more gestures?
