Hi.
Is it possible to order Zynaptik only to upgrade my v2 zynthian to 3 midi ports?
Delivery to Helsinki, Finland.
I can solder it myself if required to keep components safe on the way.
Hi.
Hi @Quadrica!
Your “AllInOne” (v2) already have the 3 MIDI ports. Most probably, if you have a “first generation” v2, your “aluminum case” has only 2 MIDI holes. In such a case, you can choose witch 2 MIDI ports (of the 3 available in the AllInOne circuit) you want.
If you really need the 3 ports simultaneously, then you should update your case, or make a new MIDI hole in the case you have
Regarding the Zynaptic, it’s an SMD circuit ready to use, but the Zynaptic connectors are not compatible with v2 connectors. Integrating a Zynaptic in a v2 is not straightforward.
Got it. The main idea was to update the box with thru socket. And my box has one midi-in only. Actually out is not required. Let me try to make midi thru based on current solution, it shouldn’t be difficult. Just a time could be the issue. I’ve expected Zynaptic is plug-n-play board needed just less than one hour of my attention.
If your box only have 1 MIDI-IN, then probably you have an v1 kit … could you send a photo of your zynthian’s backside?
