I just updated my custom Zynthian (Pi5) and there was an annoying loop at start even if webconf recognised the gear.
I realized that the issue is caused by the loading of last_state.zss
so
I renamed a simple, one chain snapshot, as last_state.zss, I uploaded it in snapshots folder
I reboot and all works perfectly.
So my suggestion is, as default, set off the setting Restore last state on startup.
What do you think?
I just flashed a new SD card using 2024-09-14-zynthianos-bookworm-aarch64-oram-2409.img.xz
At boot Zynthian falls in a loop switching between a black page and a system page where the last line is zynthian login:
to complete the installation the:
switch off
connect to network by ethernet
now I can see Zynthin by zynthian.local
change the audio default (V5 adac) to my previously working audio setup (Justboom) and reboot
finally it completes the boot but touch does not work properly: pressing on Admin voice I cannot enter in Admin submenu
I see there is an update, I launch the update
after update the touch now works perfectly so I can set WIFI network from touch screen
The installation seems OK, except for the blank screen. It seems like the splash images were not correctly generated.The autoconfig canāt detect audio cards, so connecting to webconf to do it is the normal procedure.
Regarding the touch problem, could you be more explicit?
What is your setup? Rbpi4 or 5? Logs? Etc .
This morning Zynthian at boot went once more in a loop blinking between a black page and a system page where the last line is zynthian login:
I can see Zynthian from Webconf.
I launched the update from Webconf, this is the log
xset: unable to open display ā:0ā
Updating zynthian-sys (oram)ā¦
Updated 0 paths from the index
Already up to date.
Updating System configurationā¦
SOUNDCARD_MIXER is OK
BOOT LOG ENABLED
OVERCLOCKING => None
RBPI AUDIO ENABLED
OTG ENABLED
SOUNDCARD CONFIG => dtoverlay=justboom-dac
DISPLAY CONFIG =>
CUSTOM CONFIG =>
Executing update recipesā¦
Current patch level: 20240912.1
NO NEW PATCHES TO APPLY.
UPGRADING DEBIAN PACKAGES ā¦
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
Reading package listsā¦
Building dependency treeā¦
Reading state informationā¦
Calculating upgradeā¦
The following packages have been kept back:
zynaddsubfx zynaddsubfx-data zynaddsubfx-lv2
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
Updating zynthian-dataā¦
Already up to date.
sed: couldnāt write 51 items to /zynthian/zynthian-plugins/lv2/dexed.lv2/sedY8Rb6y: No space left on device
BOOT LOG ENABLED
RBPI AUDIO ENABLED
OTG ENABLED
DISPLAY CONFIG =>
CUSTOM CONFIG =>
Updating zyncoderā¦
/zynthian/zyncoder /zynthian/zyncoder
/zynthian/zyncoder/build /zynthian/zyncoder /zynthian/zyncoder
++ Defined DUMMY_ENCODERS
++ TPA6130 kernel driver NOT LOADED. Using TPA6130 user space driver if needed.
++ Building for Wiring Layout DUMMIES
ā Configuring done
ā Generating done
ā Build files have been written to: /zynthian/zyncoder/build
[ 86%] Built target zyncore
[100%] Built target zyncoder_test
/zynthian/zyncoder
Updating zynthian-uiā¦
/zynthian/zynthian-ui/zynlibs/zynmixer /zynthian/zynthian-ui
/zynthian/zynthian-ui/zynlibs/zynmixer/build /zynthian/zynthian-ui/zynlibs/zynmixer /zynthian/zynthian-ui
ā Configuring done
ā Generating done
ā Build files have been written to: /zynthian/zynthian-ui/zynlibs/zynmixer/build
[100%] Built target zynmixer
/zynthian/zynthian-ui/zynlibs/zynaudioplayer /zynthian/zynthian-ui
/zynthian/zynthian-ui/zynlibs/zynaudioplayer/build /zynthian/zynthian-ui/zynlibs/zynaudioplayer /zynthian/zynthian-ui
OSC disabled
ā Configuring done
ā Generating done
ā Build files have been written to: /zynthian/zynthian-ui/zynlibs/zynaudioplayer/build
[100%] Built target zynaudioplayer
/zynthian/zynthian-ui/zynlibs/zynseq /zynthian/zynthian-ui
/zynthian/zynthian-ui/zynlibs/zynseq/build /zynthian/zynthian-ui/zynlibs/zynseq /zynthian/zynthian-ui
ā Configuring done
ā Generating done
ā Build files have been written to: /zynthian/zynthian-ui/zynlibs/zynseq/build
[100%] Built target zynseq
/zynthian/zynthian-ui/zynlibs/zynsmf /zynthian/zynthian-ui
/zynthian/zynthian-ui/zynlibs/zynsmf/build /zynthian/zynthian-ui/zynlibs/zynsmf /zynthian/zynthian-ui
ā Configuring done
ā Generating done
ā Build files have been written to: /zynthian/zynthian-ui/zynlibs/zynsmf/build
[100%] Built target zynsmf
Updating zynthian-webconfā¦
Regenerating engines DB: engines ā¦
INFO:root:Command took 4s
Running Flag Actions from ā/zynthian/zynthian-sys/scripts/update_zynthian.shāā¦
Update Complete
but now Zynthian is in a loop with many lines of code on screen
Starting and stopping Zynthian user interface
after thi s long loop now is in in a loop blinking between a black page and a system page where the last line is zynthian login:
Or your SD-card is too small (32GB is the minimum recommended, 16GB is not enough for the full Oram image) or for some reason the auto-expand procedure didnāt work in the first boot.
Wait! I see in the previous info from the webconf dashboard:
SD Card: 49% (14G/29G)
So it seems like an issue with your SD-card. Please try with a different one.
I have downloaded and tried to install twice the new ORAM *2024-09-14-zynthianos-bookworm-aarch64-oram-2409.
The first time after extracting .img file over a fresh 64GB card.
The second time without extracting the original .xz file. In this case, curiously, ābalena etcherā recognised it and toasted as a valid file.
Unfortunately in both cases I got the same result: nothing.
After tunrning on the machine with the new card, the screen does not pass from a black āilluminatedā status, without any vital sign as text, code strings, movement⦠nothing happens.
This morning, before leaving home, I left the card inserted several hours hopping a sort of slow process. When arrived the screen still was in black, but nothing.
Am I missing something important with this new version?
Cannot save Snapshot when midi controller is assigned to MOD-UI plugin. The assignment is done in Zynthian itself.
I was so happy to see that the lv2 plugins of MOD-UI got a bypass switch in the zynthian softwar. however⦠when I assign a controller to the bypass switch I cannot save the snapshot anymore⦠it gives an error⦠After that I have to replace the last_state.zss file otherwise the Zynthian does not startupā¦
Hi, I have the following problems with the 2024-09-14-oram version:
The display setting to WaveShare 7 HDMI+USB 1024x600 does not work correctly, in the previous old version (unfortunately, I donāt know which version I used), the settings worked without problems.
Even if I set Generic HDMI/DSI Display, I am not able to select items in Main screen by touch, switching between Main and Mixer works for me
After update I canāt login to webconf, connection times outā¦, as I reported yesterday
In terms of hardware, it is the same machine on which I ran oram without problems. Debugging MIDI - #8 by ToFF Raspbery Pi 400, without encoders and switches.
