New testing image Bookworm Oram 64bits
At the moment Fx can not be bypassed if it is not supported by plug-in itself. Not all fx plug-ins have bypass feature. If I am not mistaken @riban told me before that fx bypass feature can be implemented by zynthian software itself when configuring plug-in order inside jackd but this is not yet prioritised and maybe not a feature request yet.
Therefore, I have several chains where each have only fxs that are required and when playing mute all apart one. To mute all apart one with midi command I save each combination as zs3 mapped to a different midi command.
Here is a video of my midi controller muting all chains (when not playing) and then enabling only on chain (clean or crunchy). Don’t be confused with 3rd chain. This one is for backing track.
Hi @jofemodo
here’s my log
#                          #      ZynthianOS ORAM-2409
#            ##            #      Timestamp: 2024-09-11
#      ##   #  #   ##      #      Built from RaspberryPiOS Bookworm (aarch64)
###   #  #  #  #  #  #   ###      Kit:           Custom
#  #  #  #  #  #  #  #  #  #      Display:       Generic HDMI/DSI Display
#   ##   #  #  #  #   ##   #      Soundcard:     Default
#         ##    ##         #      Wiring Layout: DUMMIES
                                  zynthian-ui: oram (a23865)
                                  zynthian-webconf: oram (640087)
                                  zyncoder: oram (71de6d)
                                  zynthian-sys: oram (996e5e)
                                  zynthian-data: oram (6fa0db)
Linux zynthian 6.6.47-v8+ #1794 SMP PREEMPT Thu Aug 29 16:29:21 BST 2024 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
(venv) root@zynthian:~# journalctl -f -n 200
Sep 24 23:18:34 zynthian zynthian_webconf.sh[1790]: DEBUG:zynthian_lv2.load_engines: Loaded engine config with timestamp: 1727133063.4060411
Sep 24 23:18:35 zynthian zynthian_webconf.sh[1790]: Started libzynaudioplayer using libsndfile-1.2.0
Sep 24 23:18:35 zynthian zynthian_webconf.sh[1790]: INFO:zynthian_engine_audioplayer.zynthian_engine_audioplayer: Supported Audio Codecs: ['aiff', 'aifc', 'au', 'caf', 'flac', 'mp3', 'vox', 'opus', 'ogg', 'wav']
Sep 24 23:18:35 zynthian zynthian_webconf.sh[1790]: Traceback (most recent call last):
Sep 24 23:18:35 zynthian zynthian_webconf.sh[1790]:   File "/zynthian/zynthian-webconf/./zynthian_webconf.py", line 43,in <module>
Sep 24 23:18:35 zynthian zynthian_webconf.sh[1790]:     from lib.audio_config_handler import AudioConfigHandler
Sep 24 23:18:35 zynthian zynthian_webconf.sh[1790]:   File "/zynthian/zynthian-webconf/lib/audio_config_handler.py", line 36, in <module>
Sep 24 23:18:35 zynthian zynthian_webconf.sh[1790]:     if int(os.environ.get('RBPI_VERSION_NUMBER', '4')) > 4:
Sep 24 23:18:35 zynthian zynthian_webconf.sh[1790]:        ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Sep 24 23:18:35 zynthian zynthian_webconf.sh[1790]: ValueError: invalid literal for int() with base 10: 'UNSUPPORTED'
Sep 24 23:18:35 zynthian zynthian_webconf.sh[1790]: libzynaudioplayer exiting...  done!
Sep 24 23:18:35 zynthian systemd[1]: zynthian-webconf.service: Main process exited, code=exited, status=1/FAILURE
Sep 24 23:18:35 zynthian systemd[1]: zynthian-webconf.service: Failed with result 'exit-code'.
Sep 24 23:18:35 zynthian systemd[1]: zynthian-webconf.service: Consumed 2.577s CPU time.
Sep 24 23:18:38 zynthian dhcpcd[627]: eth0: using IPv4LL address 169.254.143.64
Sep 24 23:18:38 zynthian avahi-daemon[557]: Joining mDNS multicast group on interface eth0.IPv4 with address 169.254.143.64.
Sep 24 23:18:38 zynthian avahi-daemon[557]: New relevant interface eth0.IPv4 for mDNS.
Sep 24 23:18:38 zynthian avahi-daemon[557]: Registering new address record for 169.254.143.64 on eth0.IPv4.
Sep 24 23:18:38 zynthian dhcpcd[627]: eth0: adding route to 169.254.0.0/16
Sep 24 23:18:38 zynthian NetworkManager[756]: <info>  [1727216318.0685] device (eth0): Activation: starting connection 'eth0' (f8e96a47-dde1-414a-9c34-811360c11701)
Sep 24 23:18:38 zynthian NetworkManager[756]: <info>  [1727216318.0694] device (eth0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
Sep 24 23:18:38 zynthian NetworkManager[756]: <info>  [1727216318.0700] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
Sep 24 23:18:38 zynthian NetworkManager[756]: <info>  [1727216318.0711] device (eth0): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
Sep 24 23:18:38 zynthian NetworkManager[756]: <info>  [1727216318.0719] device (eth0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
Sep 24 23:18:38 zynthian dbus-daemon[558]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=756 comm="/usr/sbin/NetworkManager --no-daemon")
Sep 24 23:18:38 zynthian systemd[1]: Starting NetworkManager-dispatcher.service - Network Manager Script Dispatcher Service...
Sep 24 23:18:38 zynthian dbus-daemon[558]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Sep 24 23:18:38 zynthian systemd[1]: Started NetworkManager-dispatcher.service - Network Manager Script Dispatcher Service.
Sep 24 23:18:38 zynthian NetworkManager[756]: <info>  [1727216318.1230] device (eth0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
Sep 24 23:18:38 zynthian NetworkManager[756]: <info>  [1727216318.1236] device (eth0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
Sep 24 23:18:38 zynthian NetworkManager[756]: <info>  [1727216318.1247] device (eth0): Activation: successful, device activated.
Sep 24 23:18:40 zynthian systemd[1]: zynthian-webconf.service: Scheduled restart job, restart counter is at 24.
Sep 24 23:18:40 zynthian systemd[1]: Stopped zynthian-webconf.service - Zynthian Webconf.
Sep 24 23:18:40 zynthian systemd[1]: zynthian-webconf.service: Consumed 2.577s CPU time.
Sep 24 23:18:40 zynthian systemd[1]: Started zynthian-webconf.service - Zynthian Webconf.
Sep 24 23:18:40 zynthian zynthian_webconf.sh[1832]: ----------------------------------------------
Sep 24 23:18:40 zynthian zynthian_webconf.sh[1832]: Linux Version: bookworm
Sep 24 23:18:40 zynthian zynthian_webconf.sh[1832]: Kernel Version: 6.6.47-v8+
Sep 24 23:18:40 zynthian zynthian_webconf.sh[1832]: ZynthianOS Version: 2409
Sep 24 23:18:40 zynthian zynthian_webconf.sh[1832]: Virtualization: none
Sep 24 23:18:40 zynthian zynthian_webconf.sh[1832]: Hardware Architecture: aarch64
Sep 24 23:18:40 zynthian zynthian_webconf.sh[1832]: Hardware Model: Raspberry Pi 400 Rev 1.1
Sep 24 23:18:41 zynthian zynthian_webconf.sh[1855]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Sep 24 23:18:41 zynthian zynthian_webconf.sh[1855]: INFO:zynthian_gui_config.<module>: No Wiring Layout configured. Only touch interface is available.
Sep 24 23:18:42 zynthian zynthian_webconf.sh[1855]: DEBUG:zynthian_lv2.load_engines: Loaded engine config with timestamp: 1727133063.4060411
Sep 24 23:18:42 zynthian zynthian_webconf.sh[1855]: Started libzynaudioplayer using libsndfile-1.2.0
Sep 24 23:18:42 zynthian zynthian_webconf.sh[1855]: INFO:zynthian_engine_audioplayer.zynthian_engine_audioplayer: Supported Audio Codecs: ['aiff', 'aifc', 'au', 'caf', 'flac', 'mp3', 'vox', 'opus', 'ogg', 'wav']
Sep 24 23:18:42 zynthian zynthian_webconf.sh[1855]: Traceback (most recent call last):
Sep 24 23:18:42 zynthian zynthian_webconf.sh[1855]:   File "/zynthian/zynthian-webconf/./zynthian_webconf.py", line 43,in <module>
Sep 24 23:18:42 zynthian zynthian_webconf.sh[1855]:     from lib.audio_config_handler import AudioConfigHandler
Sep 24 23:18:42 zynthian zynthian_webconf.sh[1855]:   File "/zynthian/zynthian-webconf/lib/audio_config_handler.py", line 36, in <module>
Sep 24 23:18:42 zynthian zynthian_webconf.sh[1855]:     if int(os.environ.get('RBPI_VERSION_NUMBER', '4')) > 4:
Sep 24 23:18:42 zynthian zynthian_webconf.sh[1855]:        ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Sep 24 23:18:42 zynthian zynthian_webconf.sh[1855]: ValueError: invalid literal for int() with base 10: 'UNSUPPORTED'
Sep 24 23:18:43 zynthian zynthian_webconf.sh[1855]: libzynaudioplayer exiting...  done!
Sep 24 23:18:43 zynthian systemd[1]: zynthian-webconf.service: Main process exited, code=exited, status=1/FAILURE
Sep 24 23:18:43 zynthian systemd[1]: zynthian-webconf.service: Failed with result 'exit-code'.
Sep 24 23:18:43 zynthian systemd[1]: zynthian-webconf.service: Consumed 2.584s CPU time.
Sep 24 23:18:48 zynthian systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Sep 24 23:18:48 zynthian systemd[1]: zynthian-webconf.service: Scheduled restart job, restart counter is at 25.
Sep 24 23:18:48 zynthian systemd[1]: Stopped zynthian-webconf.service - Zynthian Webconf.
Sep 24 23:18:48 zynthian systemd[1]: zynthian-webconf.service: Consumed 2.584s CPU time.
Sep 24 23:18:48 zynthian systemd[1]: Started zynthian-webconf.service - Zynthian Webconf.
Sep 24 23:18:48 zynthian zynthian_webconf.sh[1858]: ----------------------------------------------
Sep 24 23:18:48 zynthian zynthian_webconf.sh[1858]: Linux Version: bookworm
Sep 24 23:18:48 zynthian zynthian_webconf.sh[1858]: Kernel Version: 6.6.47-v8+
Sep 24 23:18:48 zynthian zynthian_webconf.sh[1858]: ZynthianOS Version: 2409
Sep 24 23:18:48 zynthian zynthian_webconf.sh[1858]: Virtualization: none
Sep 24 23:18:48 zynthian zynthian_webconf.sh[1858]: Hardware Architecture: aarch64
Sep 24 23:18:48 zynthian zynthian_webconf.sh[1858]: Hardware Model: Raspberry Pi 400 Rev 1.1
Sep 24 23:18:49 zynthian zynthian_webconf.sh[1881]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Sep 24 23:18:49 zynthian zynthian_webconf.sh[1881]: INFO:zynthian_gui_config.<module>: No Wiring Layout configured. Only touch interface is available.
Sep 24 23:18:49 zynthian zynthian_webconf.sh[1881]: DEBUG:zynthian_lv2.load_engines: Loaded engine config with timestamp: 1727133063.4060411
Sep 24 23:18:50 zynthian zynthian_webconf.sh[1881]: Started libzynaudioplayer using libsndfile-1.2.0
Sep 24 23:18:50 zynthian zynthian_webconf.sh[1881]: INFO:zynthian_engine_audioplayer.zynthian_engine_audioplayer: Supported Audio Codecs: ['aiff', 'aifc', 'au', 'caf', 'flac', 'mp3', 'vox', 'opus', 'ogg', 'wav']
Sep 24 23:18:50 zynthian zynthian_webconf.sh[1881]: Traceback (most recent call last):
Sep 24 23:18:50 zynthian zynthian_webconf.sh[1881]:   File "/zynthian/zynthian-webconf/./zynthian_webconf.py", line 43,in <module>
Sep 24 23:18:50 zynthian zynthian_webconf.sh[1881]:     from lib.audio_config_handler import AudioConfigHandler
Sep 24 23:18:50 zynthian zynthian_webconf.sh[1881]:   File "/zynthian/zynthian-webconf/lib/audio_config_handler.py", line 36, in <module>
Sep 24 23:18:50 zynthian zynthian_webconf.sh[1881]:     if int(os.environ.get('RBPI_VERSION_NUMBER', '4')) > 4:
Sep 24 23:18:50 zynthian zynthian_webconf.sh[1881]:        ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Sep 24 23:18:50 zynthian zynthian_webconf.sh[1881]: ValueError: invalid literal for int() with base 10: 'UNSUPPORTED'
Sep 24 23:18:50 zynthian zynthian_webconf.sh[1881]: libzynaudioplayer exiting...  done!
Sep 24 23:18:51 zynthian systemd[1]: zynthian-webconf.service: Main process exited, code=exited, status=1/FAILURE
Sep 24 23:18:51 zynthian systemd[1]: zynthian-webconf.service: Failed with result 'exit-code'.
Sep 24 23:18:51 zynthian systemd[1]: zynthian-webconf.service: Consumed 2.578s CPU time.
Sep 24 23:18:56 zynthian systemd[1]: zynthian-webconf.service: Scheduled restart job, restart counter is at 26.
Sep 24 23:18:56 zynthian systemd[1]: Stopped zynthian-webconf.service - Zynthian Webconf.
Sep 24 23:18:56 zynthian systemd[1]: zynthian-webconf.service: Consumed 2.578s CPU time.
Sep 24 23:18:56 zynthian systemd[1]: Started zynthian-webconf.service - Zynthian Webconf.
Sep 24 23:18:56 zynthian zynthian_webconf.sh[1884]: ----------------------------------------------
Sep 24 23:18:56 zynthian zynthian_webconf.sh[1884]: Linux Version: bookworm
Sep 24 23:18:56 zynthian zynthian_webconf.sh[1884]: Kernel Version: 6.6.47-v8+
Sep 24 23:18:56 zynthian zynthian_webconf.sh[1884]: ZynthianOS Version: 2409
Sep 24 23:18:56 zynthian zynthian_webconf.sh[1884]: Virtualization: none
Sep 24 23:18:56 zynthian zynthian_webconf.sh[1884]: Hardware Architecture: aarch64
Sep 24 23:18:56 zynthian zynthian_webconf.sh[1884]: Hardware Model: Raspberry Pi 400 Rev 1.1
Sep 24 23:18:57 zynthian zynthian_webconf.sh[1907]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Sep 24 23:18:57 zynthian zynthian_webconf.sh[1907]: INFO:zynthian_gui_config.<module>: No Wiring Layout configured. Only touch interface is available.
Sep 24 23:18:57 zynthian zynthian_webconf.sh[1907]: DEBUG:zynthian_lv2.load_engines: Loaded engine config with timestamp: 1727133063.4060411
Sep 24 23:18:58 zynthian zynthian_webconf.sh[1907]: Started libzynaudioplayer using libsndfile-1.2.0
Sep 24 23:18:58 zynthian zynthian_webconf.sh[1907]: INFO:zynthian_engine_audioplayer.zynthian_engine_audioplayer: Supported Audio Codecs: ['aiff', 'aifc', 'au', 'caf', 'flac', 'mp3', 'vox', 'opus', 'ogg', 'wav']
Sep 24 23:18:58 zynthian zynthian_webconf.sh[1907]: Traceback (most recent call last):
Sep 24 23:18:58 zynthian zynthian_webconf.sh[1907]:   File "/zynthian/zynthian-webconf/./zynthian_webconf.py", line 43,in <module>
Sep 24 23:18:58 zynthian zynthian_webconf.sh[1907]:     from lib.audio_config_handler import AudioConfigHandler
Sep 24 23:18:58 zynthian zynthian_webconf.sh[1907]:   File "/zynthian/zynthian-webconf/lib/audio_config_handler.py", line 36, in <module>
Sep 24 23:18:58 zynthian zynthian_webconf.sh[1907]:     if int(os.environ.get('RBPI_VERSION_NUMBER', '4')) > 4:
Sep 24 23:18:58 zynthian zynthian_webconf.sh[1907]:        ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Sep 24 23:18:58 zynthian zynthian_webconf.sh[1907]: ValueError: invalid literal for int() with base 10: 'UNSUPPORTED'
Sep 24 23:18:58 zynthian zynthian_webconf.sh[1907]: libzynaudioplayer exiting...  done!
Sep 24 23:18:58 zynthian systemd[1]: zynthian-webconf.service: Main process exited, code=exited, status=1/FAILURE
Sep 24 23:18:58 zynthian systemd[1]: zynthian-webconf.service: Failed with result 'exit-code'.
Sep 24 23:18:58 zynthian systemd[1]: zynthian-webconf.service: Consumed 2.584s CPU time.
Sep 24 23:19:02 zynthian sshd[1910]: Accepted password for root from 2603:9001:3e00:4375:90e4:efd6:f12:ee9b port 50447 ssh2
Sep 24 23:19:02 zynthian sshd[1910]: pam_unix(sshd:session): session opened for user root(uid=0) by (uid=0)
Sep 24 23:19:02 zynthian systemd-logind[568]: New session 1 of user root.
Sep 24 23:19:03 zynthian systemd[1]: Created slice user-0.slice - User Slice of UID 0.
Sep 24 23:19:03 zynthian systemd[1]: Starting user-runtime-dir@0.service - User Runtime Directory /run/user/0...
Sep 24 23:19:03 zynthian systemd[1]: Finished user-runtime-dir@0.service - User Runtime Directory /run/user/0.
Sep 24 23:19:03 zynthian systemd[1]: Starting user@0.service - User Manager for UID 0...
Sep 24 23:19:03 zynthian (systemd)[1913]: pam_unix(systemd-user:session): session opened for user root(uid=0) by (uid=0)
Sep 24 23:19:03 zynthian kernel: systemd[1913]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Sep 24 23:19:03 zynthian systemd[1913]: Queued start job for default target default.target.
Sep 24 23:19:03 zynthian systemd[1913]: Created slice app.slice - User Application Slice.
Sep 24 23:19:03 zynthian systemd[1913]: Reached target paths.target - Paths.
Sep 24 23:19:03 zynthian systemd[1913]: Reached target timers.target - Timers.
Sep 24 23:19:03 zynthian systemd[1913]: Starting dbus.socket - D-Bus User Message Bus Socket...
Sep 24 23:19:03 zynthian systemd[1913]: Listening on dirmngr.socket - GnuPG network certificate management daemon.
Sep 24 23:19:03 zynthian systemd[1913]: Listening on gpg-agent-browser.socket - GnuPG cryptographic agent and passphrase cache (access for web browsers).
Sep 24 23:19:03 zynthian systemd[1913]: Listening on gpg-agent-extra.socket - GnuPG cryptographic agent and passphrase cache (restricted).
Sep 24 23:19:03 zynthian systemd[1913]: Listening on gpg-agent-ssh.socket - GnuPG cryptographic agent (ssh-agent emulation).
Sep 24 23:19:03 zynthian systemd[1913]: Listening on gpg-agent.socket - GnuPG cryptographic agent and passphrase cache.
Sep 24 23:19:03 zynthian systemd[1913]: Listening on pk-debconf-helper.socket - debconf communication socket.
Sep 24 23:19:03 zynthian systemd[1913]: Listening on dbus.socket - D-Bus User Message Bus Socket.
Sep 24 23:19:03 zynthian systemd[1913]: Reached target sockets.target - Sockets.
Sep 24 23:19:03 zynthian systemd[1913]: Reached target basic.target - Basic System.
Sep 24 23:19:03 zynthian systemd[1913]: Reached target default.target - Main User Target.
Sep 24 23:19:03 zynthian systemd[1913]: Startup finished in 306ms.
Sep 24 23:19:03 zynthian systemd[1]: Started user@0.service - User Manager for UID 0.
Sep 24 23:19:03 zynthian systemd[1]: Started session-1.scope - Session 1 of User root.
Sep 24 23:19:03 zynthian sshd[1910]: pam_env(sshd:session): deprecated reading of user environment enabled
Sep 24 23:19:04 zynthian systemd[1]: zynthian-webconf.service: Scheduled restart job, restart counter is at 27.
Sep 24 23:19:04 zynthian systemd[1]: Stopped zynthian-webconf.service - Zynthian Webconf.
Sep 24 23:19:04 zynthian systemd[1]: zynthian-webconf.service: Consumed 2.584s CPU time.
Sep 24 23:19:04 zynthian systemd[1]: Started zynthian-webconf.service - Zynthian Webconf.
Sep 24 23:19:04 zynthian zynthian_webconf.sh[2002]: ----------------------------------------------
Sep 24 23:19:04 zynthian zynthian_webconf.sh[2002]: Linux Version: bookworm
Sep 24 23:19:04 zynthian zynthian_webconf.sh[2002]: Kernel Version: 6.6.47-v8+
Sep 24 23:19:04 zynthian zynthian_webconf.sh[2002]: ZynthianOS Version: 2409
Sep 24 23:19:04 zynthian zynthian_webconf.sh[2002]: Virtualization: none
Sep 24 23:19:04 zynthian zynthian_webconf.sh[2002]: Hardware Architecture: aarch64
Sep 24 23:19:04 zynthian zynthian_webconf.sh[2002]: Hardware Model: Raspberry Pi 400 Rev 1.1
Sep 24 23:19:05 zynthian zynthian_webconf.sh[2025]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Sep 24 23:19:05 zynthian zynthian_webconf.sh[2025]: INFO:zynthian_gui_config.<module>: No Wiring Layout configured. Only touch interface is available.
Sep 24 23:19:05 zynthian zynthian_webconf.sh[2025]: DEBUG:zynthian_lv2.load_engines: Loaded engine config with timestamp: 1727133063.4060411
Sep 24 23:19:06 zynthian zynthian_webconf.sh[2025]: Started libzynaudioplayer using libsndfile-1.2.0
Sep 24 23:19:06 zynthian zynthian_webconf.sh[2025]: INFO:zynthian_engine_audioplayer.zynthian_engine_audioplayer: Supported Audio Codecs: ['aiff', 'aifc', 'au', 'caf', 'flac', 'mp3', 'vox', 'opus', 'ogg', 'wav']
Sep 24 23:19:06 zynthian zynthian_webconf.sh[2025]: Traceback (most recent call last):
Sep 24 23:19:06 zynthian zynthian_webconf.sh[2025]:   File "/zynthian/zynthian-webconf/./zynthian_webconf.py", line 43,in <module>
Sep 24 23:19:06 zynthian zynthian_webconf.sh[2025]:     from lib.audio_config_handler import AudioConfigHandler
Sep 24 23:19:06 zynthian zynthian_webconf.sh[2025]:   File "/zynthian/zynthian-webconf/lib/audio_config_handler.py", line 36, in <module>
Sep 24 23:19:06 zynthian zynthian_webconf.sh[2025]:     if int(os.environ.get('RBPI_VERSION_NUMBER', '4')) > 4:
Sep 24 23:19:06 zynthian zynthian_webconf.sh[2025]:        ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Sep 24 23:19:06 zynthian zynthian_webconf.sh[2025]: ValueError: invalid literal for int() with base 10: 'UNSUPPORTED'
Sep 24 23:19:06 zynthian zynthian_webconf.sh[2025]: libzynaudioplayer exiting...  done!
Sep 24 23:19:06 zynthian systemd[1]: zynthian-webconf.service: Main process exited, code=exited, status=1/FAILURE
Sep 24 23:19:06 zynthian systemd[1]: zynthian-webconf.service: Failed with result 'exit-code'.
Sep 24 23:19:06 zynthian systemd[1]: zynthian-webconf.service: Consumed 2.582s CPU time.
Sep 24 23:19:11 zynthian systemd[1]: zynthian-webconf.service: Scheduled restart job, restart counter is at 28.
Sep 24 23:19:11 zynthian systemd[1]: Stopped zynthian-webconf.service - Zynthian Webconf.
Sep 24 23:19:11 zynthian systemd[1]: zynthian-webconf.service: Consumed 2.582s CPU time.
Sep 24 23:19:11 zynthian systemd[1]: Started zynthian-webconf.service - Zynthian Webconf.
Sep 24 23:19:11 zynthian zynthian_webconf.sh[2028]: ----------------------------------------------
Sep 24 23:19:11 zynthian zynthian_webconf.sh[2028]: Linux Version: bookworm
Sep 24 23:19:11 zynthian zynthian_webconf.sh[2028]: Kernel Version: 6.6.47-v8+
Sep 24 23:19:11 zynthian zynthian_webconf.sh[2028]: ZynthianOS Version: 2409
Sep 24 23:19:11 zynthian zynthian_webconf.sh[2028]: Virtualization: none
Sep 24 23:19:11 zynthian zynthian_webconf.sh[2028]: Hardware Architecture: aarch64
Sep 24 23:19:11 zynthian zynthian_webconf.sh[2028]: Hardware Model: Raspberry Pi 400 Rev 1.1
Sep 24 23:19:12 zynthian zynthian_webconf.sh[2051]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Sep 24 23:19:12 zynthian zynthian_webconf.sh[2051]: INFO:zynthian_gui_config.<module>: No Wiring Layout configured. Only touch interface is available.
Sep 24 23:19:13 zynthian zynthian_webconf.sh[2051]: DEBUG:zynthian_lv2.load_engines: Loaded engine config with timestamp: 1727133063.4060411
Sep 24 23:19:13 zynthian zynthian_webconf.sh[2051]: Started libzynaudioplayer using libsndfile-1.2.0
Sep 24 23:19:13 zynthian zynthian_webconf.sh[2051]: INFO:zynthian_engine_audioplayer.zynthian_engine_audioplayer: Supported Audio Codecs: ['aiff', 'aifc', 'au', 'caf', 'flac', 'mp3', 'vox', 'opus', 'ogg', 'wav']
Sep 24 23:19:14 zynthian zynthian_webconf.sh[2051]: Traceback (most recent call last):
Sep 24 23:19:14 zynthian zynthian_webconf.sh[2051]:   File "/zynthian/zynthian-webconf/./zynthian_webconf.py", line 43,in <module>
Sep 24 23:19:14 zynthian zynthian_webconf.sh[2051]:     from lib.audio_config_handler import AudioConfigHandler
Sep 24 23:19:14 zynthian zynthian_webconf.sh[2051]:   File "/zynthian/zynthian-webconf/lib/audio_config_handler.py", line 36, in <module>
Sep 24 23:19:14 zynthian zynthian_webconf.sh[2051]:     if int(os.environ.get('RBPI_VERSION_NUMBER', '4')) > 4:
Sep 24 23:19:14 zynthian zynthian_webconf.sh[2051]:        ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Sep 24 23:19:14 zynthian zynthian_webconf.sh[2051]: ValueError: invalid literal for int() with base 10: 'UNSUPPORTED'
Sep 24 23:19:14 zynthian zynthian_webconf.sh[2051]: libzynaudioplayer exiting...  done!
Sep 24 23:19:14 zynthian systemd[1]: zynthian-webconf.service: Main process exited, code=exited, status=1/FAILURE
Sep 24 23:19:14 zynthian systemd[1]: zynthian-webconf.service: Failed with result 'exit-code'.
Sep 24 23:19:14 zynthian systemd[1]: zynthian-webconf.service: Consumed 2.577s CPU time.
Sep 24 23:19:19 zynthian systemd[1]: zynthian-webconf.service: Scheduled restart job, restart counter is at 29.
Sep 24 23:19:19 zynthian systemd[1]: Stopped zynthian-webconf.service - Zynthian Webconf.
Sep 24 23:19:19 zynthian systemd[1]: zynthian-webconf.service: Consumed 2.577s CPU time.
Sep 24 23:19:19 zynthian systemd[1]: Started zynthian-webconf.service - Zynthian Webconf.
Sep 24 23:19:19 zynthian zynthian_webconf.sh[2055]: ----------------------------------------------
Sep 24 23:19:19 zynthian zynthian_webconf.sh[2055]: Linux Version: bookworm
Sep 24 23:19:19 zynthian zynthian_webconf.sh[2055]: Kernel Version: 6.6.47-v8+
Sep 24 23:19:19 zynthian zynthian_webconf.sh[2055]: ZynthianOS Version: 2409
Sep 24 23:19:19 zynthian zynthian_webconf.sh[2055]: Virtualization: none
Sep 24 23:19:19 zynthian zynthian_webconf.sh[2055]: Hardware Architecture: aarch64
Sep 24 23:19:19 zynthian zynthian_webconf.sh[2055]: Hardware Model: Raspberry Pi 400 Rev 1.1
Sep 24 23:19:20 zynthian zynthian_webconf.sh[2078]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Sep 24 23:19:20 zynthian zynthian_webconf.sh[2078]: INFO:zynthian_gui_config.<module>: No Wiring Layout configured. Only touch interface is available.
Sep 24 23:19:20 zynthian zynthian_webconf.sh[2078]: DEBUG:zynthian_lv2.load_engines: Loaded engine config with timestamp: 1727133063.4060411
Sep 24 23:19:21 zynthian zynthian_webconf.sh[2078]: Started libzynaudioplayer using libsndfile-1.2.0
Sep 24 23:19:21 zynthian zynthian_webconf.sh[2078]: INFO:zynthian_engine_audioplayer.zynthian_engine_audioplayer: Supported Audio Codecs: ['aiff', 'aifc', 'au', 'caf', 'flac', 'mp3', 'vox', 'opus', 'ogg', 'wav']
Sep 24 23:19:21 zynthian zynthian_webconf.sh[2078]: Traceback (most recent call last):
Sep 24 23:19:21 zynthian zynthian_webconf.sh[2078]:   File "/zynthian/zynthian-webconf/./zynthian_webconf.py", line 43,in <module>
Sep 24 23:19:21 zynthian zynthian_webconf.sh[2078]:     from lib.audio_config_handler import AudioConfigHandler
Sep 24 23:19:21 zynthian zynthian_webconf.sh[2078]:   File "/zynthian/zynthian-webconf/lib/audio_config_handler.py", line 36, in <module>
Sep 24 23:19:21 zynthian zynthian_webconf.sh[2078]:     if int(os.environ.get('RBPI_VERSION_NUMBER', '4')) > 4:
Sep 24 23:19:21 zynthian zynthian_webconf.sh[2078]:        ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Sep 24 23:19:21 zynthian zynthian_webconf.sh[2078]: ValueError: invalid literal for int() with base 10: 'UNSUPPORTED'
Sep 24 23:19:22 zynthian zynthian_webconf.sh[2078]: libzynaudioplayer exiting...  done!
Sep 24 23:19:22 zynthian systemd[1]: zynthian-webconf.service: Main process exited, code=exited, status=1/FAILURE
Sep 24 23:19:22 zynthian systemd[1]: zynthian-webconf.service: Failed with result 'exit-code'.
Sep 24 23:19:22 zynthian systemd[1]: zynthian-webconf.service: Consumed 2.578s CPU time.
Sep 24 23:19:27 zynthian systemd[1]: zynthian-webconf.service: Scheduled restart job, restart counter is at 30.
Sep 24 23:19:27 zynthian systemd[1]: Stopped zynthian-webconf.service - Zynthian Webconf.
Sep 24 23:19:27 zynthian systemd[1]: zynthian-webconf.service: Consumed 2.578s CPU time.
Sep 24 23:19:27 zynthian systemd[1]: Started zynthian-webconf.service - Zynthian Webconf.
Sep 24 23:19:27 zynthian zynthian_webconf.sh[2081]: ----------------------------------------------
Sep 24 23:19:27 zynthian zynthian_webconf.sh[2081]: Linux Version: bookworm
Sep 24 23:19:27 zynthian zynthian_webconf.sh[2081]: Kernel Version: 6.6.47-v8+
Sep 24 23:19:27 zynthian zynthian_webconf.sh[2081]: ZynthianOS Version: 2409
Sep 24 23:19:27 zynthian zynthian_webconf.sh[2081]: Virtualization: none
Sep 24 23:19:27 zynthian zynthian_webconf.sh[2081]: Hardware Architecture: aarch64
Sep 24 23:19:27 zynthian zynthian_webconf.sh[2081]: Hardware Model: Raspberry Pi 400 Rev 1.1
Sep 24 23:19:28 zynthian dhcpcd[627]: eth0: carrier lost
Sep 24 23:19:28 zynthian kernel: bcmgenet fd580000.ethernet eth0: Link is Down
Sep 24 23:19:28 zynthian avahi-daemon[557]: Withdrawing address record for 169.254.143.64 on eth0.
Sep 24 23:19:28 zynthian avahi-daemon[557]: Leaving mDNS multicast group on interface eth0.IPv4 with address 169.254.143.64.
Sep 24 23:19:28 zynthian avahi-daemon[557]: Interface eth0.IPv4 no longer relevant for mDNS.
Sep 24 23:19:28 zynthian dhcpcd[627]: eth0: deleting route to 169.254.0.0/16
Sep 24 23:19:28 zynthian zynthian_webconf.sh[2104]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Sep 24 23:19:28 zynthian zynthian_webconf.sh[2104]: INFO:zynthian_gui_config.<module>: No Wiring Layout configured. Only touch interface is available.
Sep 24 23:19:28 zynthian zynthian_webconf.sh[2104]: DEBUG:zynthian_lv2.load_engines: Loaded engine config with timestamp: 1727133063.4060411
Sep 24 23:19:29 zynthian zynthian_webconf.sh[2104]: Started libzynaudioplayer using libsndfile-1.2.0
Sep 24 23:19:29 zynthian zynthian_webconf.sh[2104]: INFO:zynthian_engine_audioplayer.zynthian_engine_audioplayer: Supported Audio Codecs: ['aiff', 'aifc', 'au', 'caf', 'flac', 'mp3', 'vox', 'opus', 'ogg', 'wav']
Sep 24 23:19:29 zynthian zynthian_webconf.sh[2104]: Traceback (most recent call last):
Sep 24 23:19:29 zynthian zynthian_webconf.sh[2104]:   File "/zynthian/zynthian-webconf/./zynthian_webconf.py", line 43,in <module>
Sep 24 23:19:29 zynthian zynthian_webconf.sh[2104]:     from lib.audio_config_handler import AudioConfigHandler
Sep 24 23:19:29 zynthian zynthian_webconf.sh[2104]:   File "/zynthian/zynthian-webconf/lib/audio_config_handler.py", line 36, in <module>
Sep 24 23:19:29 zynthian zynthian_webconf.sh[2104]:     if int(os.environ.get('RBPI_VERSION_NUMBER', '4')) > 4:
Sep 24 23:19:29 zynthian zynthian_webconf.sh[2104]:        ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
This is really curious:
Please, could you send me the output from this command:
echo $RBPI_VERSION_NUMBER
Also, please, the output from this one:
cat /sys/firmware/devicetree/base/model
BTW, do you have a pi400? It’s not officially supported, although it should work with little adjustments :wink:
Yes it is a pi400, it’s my favorite test subject :joy:
I remember reading from the forum that it’s not fully supported but I’ve seen cases of pi400 being used and got it for so cheap I couldn’t resist. If it’s the cause of this issue I can always abandon it for this project.
I will send you the requested output later on. Thanks for the help.
Subject: midiTTY issue
Ok, I started from scratch. With the latest-stable image and after updating.
A simple midi setup:
create a midi chain, set input to the external device and output to midiTTY for all midi channels. In webconf enable system messages under midi option is true.
See images
webconf
If I start the external device, which sends Start/Stop/Clock messages, the output on the midiTTY is:
SYS START
SYS START <—
SYS STOP <—
SYS CLOCK
SYS CLOCK
SYS CLOCK
SYS CLOCK
which means. System messages are passed, but a strange START/STOP pair appears at the beginning. I’ll investigate in it later, when I’m back from work.
This was working before without any issues…
Anybody else observing this with an updated zynthian/freshly burnt image?
Hi @stojos,
Thanks!!
Could you send me the snapshot so I can see how it is constructed?
Have a great musical day,
Maarten
There is an issue with the patch described in
I don’t know exactly how, but the patch results in sending a START-STOP sequence, when zynthian is midi controlled externally with system messages.
It leads to the above mentioned result (New testing image Bookworm Oram 64bits - #549 by gitnob).
I deleted these lines and compiled and installed zynseq.cpp with make and make install. Restarted zynthian.
After this the regular behaviour was reverted.
This is a bug, isn’t it. Perhaps it was mentioned to allow starting patterns after external midi system messages??
You are right!
Zynthian should only send the start/stop when it’s acting as clock master.
I will take a look ASAP to fix it. It shouldn’t be difficult.
@jofemodo
this is what i got
(venv) root@zynthian:~# echo $RBPI_VERSION_NUMBER
UNSUPPORTED
(venv) root@zynthian:~# cat /sys/firmware/devicetree/base/model
I think we already established that i’m using a pi400 yesterday as my test Pi, but the first command came back unsupported.
I will fix it ASAP.
thank you
Hi @Hans_JB!
It’s fixed. Please, update and test.
Updated and webconf works now. Thank you for taking the time to fix this. :pray:t6:
Sorry fo reviving this now; I have installed Oram again due to my sd card going corrupt using the 2024-09-23-zynthianos-bookworm-aarch64-oram-2409 file. this is 14.1 gigs when extracted but now I have lost all Fluid GM presets for various instruments. At first the processor didnt pop up on screen so I had to toggle activate it from webconf but even if I load any of the instrument categories (piano, organ, bass, drums) there is only one or two basic default presets on there which once used to be a long exhaustive list on the previous version. Am i doing something wrong here?
It sounds like you are using the reduced size image that does not have soundfonts and samples. Also that image is old.
Use the latest, full image.
