OOPS: loops missing from new (github) factory SFZs
When I converted the audio to FLAC for the factory SFZs, apparently I didn’t preserve foreign metadata, so sfz’s with loops aren’t looping correctly. For an example, see Pianos/Wurt.
I’m working on the fix, so please stay tuned.
FYI @jofemodo
Fixed!
Also, Ibanez basses should be visible now, and vibrato made consistent for wurlitzer, farfisa organ, and Ibanez basses that had vibrato programmed but inconsistently. The new “consistent” vibrato is based on wurlitzer epiano vibrato. There may be better defaults for other instruments, just LMK. But the controls will work the same.
Note that this doesn’t affect vibrato for strings, which remains the same (but should now appear properly in the controls in the UI, which they didn’t before, so you had to manually enable the CCs to control them.)
Did you change some sample or only SFZ files?
Samples. The affected ones were ones where the loop was in the smpl chunk in the .wav file.
