ORAM with Zynthian V4: webconf not loaded using zynthian.local and other pb
before opening a ticket…
Zynthian V4, after this update:
zyncoder: oram (62626a8)
zynthian-ui: oram (3fdc524)
zynthian-sys: oram (5affa51)
zynthian-data: oram (e222e11)
zynthian-webconf: oram (0327ac4)
has these issues:
1 - webconf cannot be loaded using zynthian.local and zynthian.lan but can be loaded by IP
2- after loading a snapshot made of Fluidsynth jRhodes4 + autopan if I add in series Giant flange,
ERROR CUIA zynswitch: (3, ‘5’) is shown
furthermore I noticed a general instability because trying prepare snapshots adding and changing effects I had to reboot the system
HARDWARE
Raspberry Pi 4 Model B Rev 1.4
Audio: HifiBerry DAC+ ADC PRO
Display: ZynScreen 3.5 (v1)
Wiring: MCP23017_ZynScreen
I2C: MCP23017@0x20
Profile: v4_stage
SYSTEM
Build Date: 2024-05-21
Memory: 11% (866M/7810M)
SD Card: 66% (37G/58G)
Temperature: 56.9ºC
Overclock: None
Has it previously loaded at zynthian.local…?
Since the IP address works there is a distinct possibility that names aren’t being successfully resolved on your network.
Can you get ssh ssh -X root@zynthian.local access with zynthian.local or the IP address?
I can’t find an engine called jRhodes3. I assume you means TAP AutoPanner.
Anyway - to simplify the issue, it fails when loading Giant flange plugin, even to an empty audio chain. I suggest you raise a ticket. [Edit] This is fixed in latest commit (although I can’t get Giant flange to sound useful).
Regarding network access. Have you changed your other network connection, e.g. connected to a different network, changed router, etc? You don’t say whether this is wired or wireless. Nor do you show the Network part of the dashboard.
Is it a legacy snapshot or you created from scratch?
@riban JRhodes 3 under Fluidsynt
@Jofemodo it is a legacy snapshot
I updated and with this situation:
zynthian-ui: oram (9600ef4)
this problem is solved:
2- after loading a snapshot made of Fluidsynth with jRhodes4 + autopan if I add in series Giant flange , ERROR CUIA zynswitch: (3, ‘5’) is shown
We would need the snapshots and the UI logs, if possible.
I hope this is enough
UI Log
Aug 06 08:31:13 zynthian startx[916]: WARNING:zynthian_state_manager.load_zs3: Failed to restore MIDI learning 68 => legato
Aug 06 08:31:13 zynthian startx[916]: WARNING:zynthian_state_manager.load_zs3: Failed to restore MIDI learning 2 => breath
Aug 06 08:31:13 zynthian startx[916]: WARNING:zynthian_state_manager.load_zs3: Failed to restore MIDI learning 65 => portamento on/off
Aug 06 08:31:13 zynthian startx[916]: WARNING:zynthian_state_manager.load_zs3: Failed to restore MIDI learning 5 => portamento time-coarse
Aug 06 08:31:13 zynthian startx[916]: WARNING:zynthian_state_manager.load_zs3: Failed to restore MIDI learning 37 => portamento time-fine
Aug 06 08:31:13 zynthian startx[916]: WARNING:zynthian_state_manager.load_zs3: Failed to restore MIDI learning 84 => portamento control
Aug 06 08:31:13 zynthian startx[916]: WARNING:zynthian_state_manager.load_zs3: Failed to restore MIDI learning 74 => filter cutoff
Aug 06 08:31:13 zynthian startx[916]: WARNING:zynthian_state_manager.load_zs3: Failed to restore MIDI learning 71 => filter resonance
Aug 06 08:31:13 zynthian startx[916]: WARNING:zynthian_state_manager.load_zs3: Failed to restore MIDI learning 73 => env. attack
Aug 06 08:31:13 zynthian startx[916]: WARNING:zynthian_state_manager.load_zs3: Failed to restore MIDI learning 72 => env. release
default.zss (6.7 KB)
I thought the issue was resolved. What is the current problem? This is why using the issue tracker with one issue per ticket is advantageous.
remaining issue:
