Been trying to get my head around how I can have my Pyramid Sequencer load sounds from the Zynth when I open a project.
I’m not expecting you to know how the Pyramid works but you may be able to point me in the right direction and I may have missed something on the Zynth.
So correct me if I’m wrong but to be able to recall the engines and patches I have used, I have to have made a snapshot.
So what I did was create 3 tracks on my Pyramid, sending them to MIDI 1, 2, 3
Created 3 layers on the Zynth, mapped to MIDI 1, 2, 3
Recorded some notes
Everything played back fine
Saved the Snapshot, then renamed it in the webUI
I then Removed all the Zynth Layers to then try and work out how I recall it.
I also noticed on the webUI my snapshot has a Program/Bank (000/002)
So on the Pyramid I have this window
PC - MSB - LSB < this looks like the right place.
It was my hope that changing these values would call the snapshot and on play, my sounds would load.
Unfortunately not - the Zyth crashed. Well the UI did, I could force a restart.
So I then manually loaded the snapshot
But only MIDI channel 1 played, 2 and 3 were silent.
However, if I selected Track 2 on my Pyramid, and moved the knob for the PC parameter, the presets for that layer started cycling through and I could find the one I wanted.
The same for track 3.
The Project then played
While that is really neat that I can move though the presets from the Zynth on my Pyramid, as soon as I removed all the layers and reloaded the snapshot, channels 2 and 3 were silent again.
So I guess after all that preamble (sorry
Has anyone any idea why only midi channel 1 plays when loading a snapshot?
Am I able to call a snapshot via program change?
Just wondering if i’m missing a Zynth setting or something obvious and I have seen at least one member mention they have a Pyramid.
Any suggestions welcome
