Do consider whether there is benefit in maintaining a non-quantized version of the pattern. It seems like a great feature but how much use will it actually get? I don’t think many users would miss it if they never had it but instead had a way to quantize a pattern with undo option. Also, live quantization is more resource hungry that rendered quantize pattern. We could have a shadow pattern that is quantized.
This is how pattern undo/redo history works.
Currently this history is not saved. It could be interesting to save It.
regards
Hi @zynthianers!
I just pushed some improvements to Vangelis branch (testing). Now quantization is performed in real time. Captured notes are ALWAYS not quantized and you can enable/disable quantization while playinng at any time. I think this is the expected behaviour, right?
TODO: Quantization to fraction of step. Current quantization is to 1 step.
@gilrain, does this improve your workflow in some way?
Anyway, i’m thinking of implementing this:
- when “creating” a pattern, take config from last pattern in the same group.
but my ears are open to fresh ideas.
All the best,
Thank you, it works.
This would be the real solution to the original request.
