Questions about zynthian OS automated build system
Right, so I finally made it!!
I only had to edit the jack config from the web interface, according to the listed device by aplay.
Now I’m facing another issue:
ERROR:zynthian_gui.refresh_status: [Errno 2] No such file or directory: ‘vcgencmd’: ‘vcgencmd’
I see that this is raspbian-specific, so I might as well get into the python code and place some dummy values. At this moment, the UI does not do anything, besides flashing an “m” when pressing keys and some x-runs from time-to-time (which kind of worries me, but that is without doing any cpu governor changes).
Keybindings do not work. Moving through the menu items with the arrows do nothing. I’m suspecting it’s because of that pesky error.
Yes ! At least you’ve managed to get the display to work. Well done. Webconf is running too and you’re not that far to get it done .
Usually the IP error splash screen comes when the the audio sub system isn’t well configured (jack server or alsa stuff).
That’s why I would say that messages are in “contratictions”:
Logs from webconf seems to told that Jackd sound server isn’t running while systemctl screenshot shows a jack running instance.
This could be helpfull:
  • What is your audio setup (hardware and how it is configured in webconf)
  • A copy of webconf home page
  • Output of lsmod, dmesg, aplay -l, aplay -L commands
Excellent.
Do you have the Zynthian UI up ?
What about trying to use a USB mouse?
Yes, I have it.
I tried customizing it from the webconf and it works, I now have a CPU load indicator. However… the rest of the UI is still frozen.
@Baggypants Tried with my mouse-keyboard combo, as well as with another mice. I can see the cursor, but it’s not moving.
Also, got rid of that previous error, it was a quick fix.
I got a new error now :smiley: :
ERROR:zynthian_gui.osc_init: ZYNTHIAN-UI OSC Server can’t be started: server error 9904: b’cannot find free port’
Nov 02 23:33:28 zynthian startx[3246]: Exception in thread Thread-9:
Nov 02 23:33:28 zynthian startx[3246]: Traceback (most recent call last):
Nov 02 23:33:28 zynthian startx[3246]: File “/usr/lib/python3.7/threading.py”, line 917, in _bootstrap_inner
Nov 02 23:33:28 zynthian startx[3246]: self.run()
Nov 02 23:33:28 zynthian startx[3246]: File “/usr/lib/python3.7/threading.py”, line 865, in run
Nov 02 23:33:28 zynthian startx[3246]: self._target(*self._args, **self._kwargs)
Nov 02 23:33:28 zynthian startx[3246]: File “./zynthian_gui.py”, line 1293, in zyncoder_thread_task
Nov 02 23:33:28 zynthian startx[3246]: self.osc_receive()
Nov 02 23:33:28 zynthian startx[3246]: File “./zynthian_gui.py”, line 298, in osc_receive
Nov 02 23:33:28 zynthian startx[3246]: while self.osc_server.recv(0):
Nov 02 23:33:28 zynthian startx[3246]: AttributeError: ‘zynthian_gui’ object has no attribute ‘osc_server’
Right, after further investigations, it seems like the gui is not listening to the keybindings. A bit late here to troubleshoot right now, but the debug log lines in the ui python file don’t reflect in the webconf UI logs.
run ss -plunt and post the output. Armbian may have some other remote config service listening on port 8000 or 9000 or something.
Netid   State    Recv-Q   Send-Q     Local Address:Port      Peer Address:Port
udp     UNCONN   0        0                0.0.0.0:68             0.0.0.0:*        users:(("dhcpcd",pid=1709,fd=12))
udp     UNCONN   0        0                0.0.0.0:111            0.0.0.0:*        users:(("rpcbind",pid=612,fd=5),("systemd",pid=1,fd=36))
udp     UNCONN   0        0                0.0.0.0:36490          0.0.0.0:*        users:(("avahi-daemon",pid=1619,fd=14))
udp     UNCONN   0        0                0.0.0.0:5353           0.0.0.0:*        users:(("avahi-daemon",pid=1619,fd=12))
udp     UNCONN   0        0              127.0.0.1:323            0.0.0.0:*        users:(("chronyd",pid=1763,fd=5))
udp     UNCONN   0        0                0.0.0.0:1370           0.0.0.0:*        users:(("zynthian_gui.py",pid=1920,fd=20))
udp     UNCONN   0        0                   [::]:45042             [::]:*        users:(("avahi-daemon",pid=1619,fd=15))
udp     UNCONN   0        0                      *:546                  *:*        users:(("dhcpcd",pid=1709,fd=15))
udp     UNCONN   0        0                   [::]:111               [::]:*        users:(("rpcbind",pid=612,fd=7),("systemd",pid=1,fd=38))
udp     UNCONN   0        0                   [::]:5353              [::]:*        users:(("avahi-daemon",pid=1619,fd=13))
udp     UNCONN   0        0                  [::1]:323               [::]:*        users:(("chronyd",pid=1763,fd=6))
tcp     LISTEN   0        128              0.0.0.0:111            0.0.0.0:*        users:(("rpcbind",pid=612,fd=4),("systemd",pid=1,fd=35))
tcp     LISTEN   0        128              0.0.0.0:80             0.0.0.0:*        users:(("zynthian_webcon",pid=1640,fd=3))
tcp     LISTEN   0        128              0.0.0.0:22             0.0.0.0:*        users:(("sshd",pid=1781,fd=3))
tcp     LISTEN   0        128              0.0.0.0:443            0.0.0.0:*        users:(("zynthian_webcon",pid=1640,fd=8))
tcp     LISTEN   0        128                 [::]:111               [::]:*        users:(("rpcbind",pid=612,fd=6),("systemd",pid=1,fd=37))
tcp     LISTEN   0        128                 [::]:80                [::]:*        users:(("zynthian_webcon",pid=1640,fd=4))
tcp     LISTEN   0        128                 [::]:22                [::]:*        users:(("sshd",pid=1781,fd=4))
tcp     LISTEN   0        128                 [::]:443               [::]:*        users:(("zynthian_webcon",pid=1640,fd=9))
I also found this in the journalctl, right after starting the UI
Nov 03 10:49:35 zynthian systemd[1]: Starting MOD ttymidi...
Nov 03 10:49:36 zynthian jack_wait[2203]: server is available
Nov 03 10:49:36 zynthian systemd[1]: Started MOD ttymidi.
Nov 03 10:49:36 zynthian ttymidi[2206]: /dev/ttyAMA0: No such file or directory
Nov 03 10:49:36 zynthian systemd[1]: mod-ttymidi.service: Main process exited, code=exited, status=255/EXCEPTION
Nov 03 10:49:36 zynthian systemd[1]: mod-ttymidi.service: Failed with result 'exit-code'.
Nov 03 10:49:37 zynthian systemd[1]: mod-ttymidi.service: Service RestartSec=1s expired, scheduling restart.
Nov 03 10:49:37 zynthian systemd[1]: mod-ttymidi.service: Scheduled restart job, restart counter is at 9.
Nov 03 10:49:37 zynthian systemd[1]: Stopped MOD ttymidi.
Nov 03 10:49:37 zynthian systemd[1]: mod-ttymidi.service: Start request repeated too quickly.
Nov 03 10:49:37 zynthian systemd[1]: mod-ttymidi.service: Failed with result 'exit-code'.
Nov 03 10:49:37 zynthian systemd[1]: Failed to start MOD ttymidi.
I have no idea where ttymidi comes in handy, but I can see the midi events in the webconf.
Also @riban since I saw that you are the author of keybind feature, can you give us a very brief introduction on how this feature works? That would hopefully aid in finding out why there are no debug logs on that part.
I don’t know if the frozen mouse pointer has anything to do with that.
@jofemodo I saw that there were similar issues in september, with frozen UI. Is this linked in any way to that?
LE:
FIXED! :smiley:
All I needed to do is to install xserver-xorg-input-evdev and xserver-xorg-input-mouse.
Original post:
Alright, so I did some more digging and found out that the displays are rendered using Tkinter on a canvas-basis system.
Initially I thought the UI is frozen because of a main-thread lock issue (looks to be very common with tkinter), but since I found out that the midi icon, the CPU load and so on are being displayed on a status canvas, this is out of the question. So tkinter is working.
But the issue looks like there’s no input to tkinter for either mouse pointer/buttons or keyboard.
I may be wrong but tkinter runs on top of X, thus X should be passing any mouse/keyboard events to tkinter.
So, my suspicion is that X does not properly handle the inputs.
libinput-bin and libinput10 are installed.
Are your mice mounted in any way under /dev?
Maybe X is looking for the mouse on some specific path which does not exist OR the mouse/keyboard are not automounted properly
Found these lines at the end of X log:
[  2729.172] (II) config/udev: Adding input device r_gpio_keys (/dev/input/event0)
[  2729.172] (II) No input driver specified, ignoring this device.
[  2729.172] (II) This device may have been added with another device file.
[  2729.179] (II) config/udev: Adding input device 2.4G Wireless Keyboard&Mouse (/dev/input/event1)
[  2729.179] (II) No input driver specified, ignoring this device.
[  2729.179] (II) This device may have been added with another device file.
[  2729.183] (II) config/udev: Adding input device 2.4G Wireless Keyboard&Mouse (/dev/input/event2)
[  2729.184] (II) No input driver specified, ignoring this device.
[  2729.184] (II) This device may have been added with another device file.
[  2729.188] (II) config/udev: Adding input device 2.4G Wireless Keyboard&Mouse (/dev/input/event3)
[  2729.188] (II) No input driver specified, ignoring this device.
[  2729.189] (II) This device may have been added with another device file.
[  2729.193] (II) config/udev: Adding input device 2.4G Wireless Keyboard&Mouse Consumer Control (/dev/input/event4)
[  2729.193] (II) No input driver specified, ignoring this device.
[  2729.193] (II) This device may have been added with another device file.
[  2729.197] (II) config/udev: Adding input device 2.4G Wireless Keyboard&Mouse System Control (/dev/input/event5)
[  2729.197] (II) No input driver specified, ignoring this device.
[  2729.197] (II) This device may have been added with another device file.
[  2729.202] (II) config/udev: Adding input device GeneralPlus USB Audio Device (/dev/input/event6)
[  2729.202] (II) No input driver specified, ignoring this device.
[  2729.202] (II) This device may have been added with another device file.
[  2729.206] (II) config/udev: Adding input device sunxi-ir (/dev/input/event7)
[  2729.206] (II) No input driver specified, ignoring this device.
[  2729.206] (II) This device may have been added with another device file.
LE1:
Managed to get the kernel output on the display.
Apparently dtoverlays are installed using an armbian tool
Got an overlay for opizero which I modified to run on SPI0 instead of SPI1 and changed some pins.
Also installed xserver-xorg-video-fbturbo.
Now fb1 appears under /dev but X is still crashing
Failed to load module "fbturbo" (module does not exist, 0)
and
[ 2465.451] (II) LoadModule: "fbdevhw" [ 2465.452] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so [ 2465.452] (II) Module fbdevhw: vendor="X.Org Foundation" [ 2465.453] compiled for 1.20.4, module version = 0.0.2 [ 2465.453] ABI class: X.Org Video Driver, version 24.0 [ 2465.453] (II) FBDEV(0): using /dev/fb1 [ 2465.453] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support [ 2465.453] (EE) Screen 0 deleted because of no matching config section. [ 2465.453] (II) UnloadModule: "fbdev" [ 2465.453] (II) UnloadSubModule: "fbdevhw" [ 2465.453] (EE) Device(s) detected, but none match those in the config file. [ 2465.453] (EE) Fatal server error: [ 2465.453] (EE) no screens found(EE) [ 2465.453] (EE)
Original post:
Right, since the UI works now and all the bells and whistles, I played a bit with zynthian over HDMI. I am really amazed by the performance and flexibility of it.
No xruns, but sporadic UI crashes from time to time, nothing major. Thanks a lot to everyone who made and contributed to this project!
The next big challenge now is though, adding a screen to this contraption.
Bought an ili9341 screen and tested it on a stm32 to make sure it works, at least, and it does indeed.
However, it doesn’t on the orange pi…
Issues:
  1. fbtft wasn’t built-in to the kernel (I’m running 5.10) so loaded it as a kernel module.
  2. fbtft_devices was removed since 5.40 and I see that also zynthian is using dtoverlays. Rpi_screen should work for me since I see that it’s meant for an ili9341. Since I am not running a standard raspberry pi configuration, I will have to override some pin configuration (cs, dc, reset), which should be done in UI in the advanced display settings.
  3. Even though I configured everything correctly, I can’t see fb1 under /dev, and I’m clueless at this point. Any help I found online relates to fbtft_devices not starting, but since this is now removed, I don’t really know what’s the cause…
  4. Is fbtft listing the framebuffer device only after it has found a device on the spi interface?
    Is there a specific HAL that fbtft is using to control the hardware pins?
    Because that would be different from the raspi.
Hi @xanderz I’m glad to hear that you’ve made some progresses.
  • It’s strange that your board doesn’t support 2 displays.
  • looks like you have to compile it :hugs: and even configure it (in /usr/share/X11/xorg.conf.d/99-fbturbo.conf or so).
    Something like (as from here):
Section “Device”
Identifier “Allwinner A10/A13 FBDEV”
Driver “fbturbo”
Option “fbdev” “/dev/fb1”
Option “SwapbuffersWait” “true”
EndSection
Off topic:
These SPI display are a real pain to handle. The fbtft lib that was working (with more or less hassle) on previous kernels versions is since a couple of years in the stagging kernel driver directory <=> not in the official source tree.
I’ve read elsewhere on some kernel developer mailing list that it’s quiet impossible to integrate it in the kernel source tree because of the new enhancements made in the kernel video layer.
Well I got it working for me, after some head banging on the table :smiley:
I was experiencing a major performance loss versus the HDMI scenario.
Lots of Xruns, and the FPS wasn’t very high either (something in the lines of like 20FPS), that is, with a 48MHz clock and the display being a 320x240.
I didn’t look on the source code yet, but I am only hoping they are not involving CPU for each byte transfer from the framebuffer, but using the DMA.
In some other words, the CPU usage wasn’t high either, so I don’t know what’s the root cause of that performance loss… I’ll have yet to investigate more :roll_eyes:
But maybe that’s only on my side. What’s your experience with fbtft(with newer kernels, preferably)?
I’m trying to build a Zynthian image. I followed the instructions in the README.rst but I’ve come up against a few errors. One I can’t get past is a problem with the openssl command not accepting command line arguments provided in start_chroot_script. I’m guessing this is because the instructions say to use 2017-12-20_2017-11-29-realtimepi-stretch-lite-0.2.zip which is now quite old. In a typical scenario I would next inspect the Jenkins job to see which image is being used now. However, I’ve not been able to find any information about the Jenkins job. There is no Jenkinsfile anywhere in the Zythian organisation on GitHub.
Could you tell me if there is any information about the Jenkins job that I’ve missed? Is it possible to view the logs for ZynthianOS Jenkins jobs?
Thanks,
rah
@jofemodo how are you guys building these days?
There is (was?) a jenkins server, but I am not sure it was using a Jenkinsfile, also I don’t see it built anything the past 2 years.
Also AFAIK realtimepi is not being really used these days. I could update it, or someone could install these, which is what realtimepi uses:
Hi @guysoft !
Currently we are building the images “by hand”. We use a set of scripts to generate a new image from the previous one, updating packages and specific zynthian software as needed. It’s an incremental procedure that produces more stable images than generating images from scratch.
We generate a new image from scratch when moving to a major debian version, every 2 years more or less.
All the best,
Are these scripts available in git? Assuming so, could you tell me where?
How do you generate a new image, using the same scripts?
Thanks,
rah
No sorry, these scripts are being used internally and i had no time/interest to release them publicly by now, as they are quite tricky and need some supervision and deep understanding of what is going on.
You can use the current setup script included in the zynthianh-sys repository:
scripts/setup_system_raspioslite_64bit_bookworm.sh
But again, this script is just a guide and it’s not intended to be run unattended. You would need some understanding of what is going on to get a functional image at the end of the process.
Anyway, why do you want to generate an image from scratch? Do you want to generate an image for another platform? Could you give some details about your goals?
Excellent, thanks.
Do you have any desire to automate the image generation? To me, minimising manual labour is always very high priority, as all free software projects inevitably have scant manpower. CI/CD is the done thing these days.
I expect it. I’m used to working with Arm-based systems and generating images. As a software engineer, typically to get aquainted with a project I like to go through the process of starting from scratch and producing the final deliverable whatever, often following a CI/CD pipeline. In this case, as is often the case with Arm-based systems, the final deliverable is the OS image. Also, as a free software user and advocate of old, I always expect to be able to build myself binaries that other people are offering, be that binary executables produced from source code or binary OS images produced from scripts and packages.
My focus right now is on a Raspberry Pi-based Zynthian. In future I may want to generate images for other platforms.
I guess I don’t really have specific concrete goals in general, except to jam with gear based on free software. That said, I have come up against niggles with Zynthian which I can fix so I’m in the process of doing that. Generating an image myself is the first step in that process, as discussed above.
Cheers,
rah
