After downloading the latest zynthian os and installing on my new pi 4 I’m finding that the setBfree synth crashes the ui every time I try to load it.
Hi @m0rvj !
There is a bug with latest stable and favorites on setBfree. If you have favorites for setBfree, you should remove them for getting setBfree to work again. Simply use this command for command line:
# rm -f /zynthian/zynthian-my-data/preset-favorites/BF.json
and restart your zynthian. It should work.
The problem is solved in testing. I will merge this fix and some others on stable ASAP.
Sweet thanks!
Did you solve it?
Yes very grateful.
