Hello @Harm and @mheidt,
I got the same problem that after choosing Single Channel Mode the Zynthian symbol is moving on and on…
I got the following if I start my zynthian via
/zynthian/zynthian-sys/sbin/zynthian.sh
X.Org X Server 1.18.4
Release Date: 2016-07-19
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.4.26-v7+ armv7l Raspbian
Current Operating System: Linux zynthian 4.14.93-v7+ #1189 SMP Mon Jan 14 16:52:29 GMT 2019 armv7l
Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Build Date: 11 November 2016 11:59:59AM
xorg-server 2:1.18.4-2+rpi1 (https://www.debian.org/support)
Current version of pixman: 0.33.3
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: “/var/log/Xorg.0.log”, Time: Sun Jan 27 17:22:28 2019
(==) Using config directory: “/etc/X11/xorg.conf.d”
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
INFO:root:Wiring Layout MCP23017_ENCODERS
DEBUG:root:ZYNCODER A: [102, 105, 110, 113]
DEBUG:root:ZYNCODER B: [101, 104, 109, 112]
DEBUG:root:SWITCHES layout: [100, 103, 108, 111]
DEBUG:root:DISABLED_MIDI_IN = [’’]
DEBUG:root:ENABLED_MIDI_OUT = [‘ttymidi:MIDI_out’, ‘QmidiNet:in_1’]
WARNING:root:Using default ENABLED MIDI FB ports
ZynMidiRouter: MIDI tuning frequency set to 440 Hz (8192)
INFO:root:ZYNSWITCHES INIT…
INFO:root:SETUP ZYNSWITCH 0 => wpGPIO 100
INFO:root:SETUP ZYNSWITCH 1 => wpGPIO 103
INFO:root:SETUP ZYNSWITCH 2 => wpGPIO 108
INFO:root:SETUP ZYNSWITCH 3 => wpGPIO 111
INFO:root:STOPPING QMIDINET
DEBUG:root:ZCTRL ‘Layer’: 0 (0 -> 7), None, None
DEBUG:root:Snapshot ‘001’ => MIDI program 0.
DEBUG:root:Snapshot ‘002’ => MIDI program 1.
DEBUG:root:Snapshot ‘003’ => MIDI program 2.
DEBUG:root:ZCTRL ‘Snapshot’: 0 (0 -> 3), None, None
INFO:root:Short Switch 1
DEBUG:root:CLOSE MODAL => snapshot
DEBUG:root:BACK TO SCREEN => layer
DEBUG:root:BACK TO SCREEN => admin
DEBUG:root:ZCTRL ‘Action’: 0 (0 -> 19), None, None
INFO:root:Short Switch 3
INFO:root:Single Channel Mode ON
WARNING:root:zynthian_gui.zyncoder_read() => list index out of range
I hope this might help tracing what’s wrong…
I wish you a nice evening and God bless you, Marius
