Some Update Issues
(in tomita after update:)
318 if chain and chain.is_midi() and chain != self.chain and (chain.midi_chan < 16 || chain.midi_chan == 0xffff):
Should be:
318 if chain and chain.is_midi() and chain != self.chain and (chain.midi_chan < 16 or chain.midi_chan == 0xffff):
Cheers,
Maarten
Ups! I pushed a fast change without testing. It’s already fixed!
Updated 0 paths from the index
Regenerating engines DB: engines …
import-im6.q16: UnableToOpenXServer ' @ error/import.c/ImportImageCommand/346. import-im6.q16: UnableToOpenXServer ’ @ error/import.c/ImportImageCommand/346.
import-im6.q16: UnableToOpenXServer ' @ error/import.c/ImportImageCommand/346. ./zynthian_lv2.py: line 37: from: command not found ./zynthian_lv2.py: line 38: from: command not found ./zynthian_lv2.py: line 40: from: command not found ./zynthian_lv2.py: line 41: from: command not found ./zynthian_lv2.py: line 48: syntax error near unexpected token (’
./zynthian_lv2.py: line 48: `class EngineType(Enum):’
Solved this with:
cd /zynthian/zynthian-ui/zyngine
root@zynthian:/zynthian/zynthian-ui/zyngine# β†’ sed -i β€˜1i #!/usr/bin/env python3’ zynthian_lv2.py
root@zynthian:/zynthian/zynthian-ui/zyngine# β†’ chmod +x zynthian_lv2.py
root@zynthian:/zynthian/zynthian-ui/zyngine# β†’ ./zynthian_lv2.py engines
Cheers,
Maarten
Ohhhh!! Arggghhhhhh!
It seems that the first line from this file vanished for some reason. And this broke a bunch of things, like the engine and preset DB regeneration.
I suspect someone was AI-refactoring zynthian code without having the test-safety-net in place and well … :wink:
Luckily, this is only in tomita branch. => Please, tell the branch ALWAYS when reporting a bug!
Now, it’s fixed again.
Should I report on Github?
And… I will put a copy of te repositories in my feedback in the fulture!
Thanks for your great application!! I love it!!
Cheers,
Maarten
