Let us know, if you need a value in the option list.
You mean the predefined setup in a drop-down? I’m good with custom, thanks, but it might be useful to others…
Not as kit but “Wiring”.
It’s not a big deal. I am going to remove one soon. If you tell me yours and how I should name it, I would be glad to.
Well, at the moment I’ve called it mytft for the lack of understanding how this display should be called beside cheap tft from aliexpress
WorldChips240x320?
And the compiled version should have a proper name. We should put the dts file into the image as well, so that it is taken when you select the display.
Ah, and you didn’t change any other values in the webconf to make it work?
World Chips is a distributor name, there are tons of other noname screens like this on ali. So I guess something like ILI9321-320x240-no-touch will fit better
yep, everything on the screenshot is all it is. I did change the pins and max speed in the dts, though. I was to lazy to rewire it the way default rpi-display should be wired ![]()
