Do you how to do an easy split ?
I try to use “Midi keysplit FX” but I don’t understand why no sound.
Maybe a tutorial for the dummy ?
Brgs
Brgs
Try “key range & transpose” in chain options. Combined with “clone midi to…” this will allow you to create key-zones for each chain and play the chains simultaneously.
Thanks for your reply but it is too complex to use it in live.
Is there a bug in “midi keyssplit FX” ?
Is it possible to have it working?
Brgs
Update Splitting keyboard
To use two different sounds on the same keyboard you can do it this way.
Add two instrument chains and select “all midi channels” with both instruments. Then you can use the OPT button to select the key range for each.
If you use the whole key range for both synth engines you can also stack them as long as the CPU is sufficient. This way you can create very unique sounds. Very powerful. Almost a Leviasynth?
See also this
Thank you for your video. I didn’t find it before. When I was looking for splitting keyboard I only found this post which didn’t really help me. So I thought updating it would help others.
Now having watched your Video that’s of course a much better explanation. Thank you for the hint with the multitimbral mode. Very helpful indeed.
You could prefer to simply use the same MIDI channel, on both chains. No need to selec ALL MIDI Chans.
Note that you need to enable Active MIDI Channel from the admin menu.
Thank you for the suggestion. I tried before to put two instruments on the same channel but somehow only one was played at a time. Maybe I did something wrong in other settings who prevented the playing of both at the same time? But with all midi channels it worked. I will try again.
Workflows are an excellent way of showing precisely what was done to reach a particular setup..
Talk:Zynthian Wiki Home - ZynthianWiki.
It’s item 2.2 in the list.
Did you check this?
Thank you @jofemodo I did try it and it worked too
. I put both instruments on Midi Channel 1 and enabled “active MIDI Channel”
