Stuck in boot loop [Solved]
just flashed the sd card, inserted to raspberry pi, nothing attached except hdmi monitor. This screen flashes then turns to black, and repeats every 2 seconds. I have also tried with my scarlet 2i2 connected, no difference.
Can you see the webconf with a browser …?
oh yes i actually could. i guess i need to change soundcard? is there a way to use the built in one?
okey, once i selected custom kit i could start fiddling with different audio interfaces etc. is there a guide to non-kit setups ive missed?
With these settings, i get to the zynthian ERROR IP: 192.168.10.100 screen.
I’ve also tried Wiring: Dummy, same error there
Alright. For unknown reason it has now successfully booted into the UI with
Soundcard: Dummy
Display: Generic HDMI
Wiring: Dummy
But i get no sound (from raspberrys built in audio port) any ideas? :slight_smile:
Soundcard: Dummy
You need to change to internal sound
It’s easy to miss it cos it’s probably in the scrolled down section
Rbpi On-Board Analog Audio.
it popped up with the buster image :+1:
Excellent!
and so the inevitable question :face_with_monocle: raises it’s ugly head . . . .
