I’ve noticed the following in my UI log and wondered if there anything to be concerned about?
I was just about to image my SD card but thought I should probably check this out first .
Its been like it for a few days but has not, that I can detect, affected performance.
– Logs begin at Thu 2016-11-03 17:16:42 GMT. –
Feb 26 17:44:49 zynthian startx[432]: xorg-server 2:1.19.2-1+rpt1+deb9u2 (https://www.debian.org/support)
Feb 26 17:44:49 zynthian startx[432]: Current version of pixman: 0.34.0
Feb 26 17:44:49 zynthian startx[432]: Before reporting problems, check http://wiki.x.org
Feb 26 17:44:49 zynthian startx[432]: to make sure that you have the latest version.
Feb 26 17:44:49 zynthian startx[432]: Markers: (–) probed, (**) from config file, (==) default setting,
Feb 26 17:44:49 zynthian startx[432]: (++) from command line, (!!) notice, (II) informational,
Feb 26 17:44:49 zynthian startx[432]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Feb 26 17:44:49 zynthian startx[432]: (==) Log file: “/var/log/Xorg.0.log”, Time: Wed Feb 26 17:44:49 2020
Feb 26 17:44:49 zynthian startx[432]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Feb 26 17:44:49 zynthian startx[432]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
