# Using Zynaptik module for encoders \[SOLVED!\]
**URL:** <https://discourse.zynthian.org/t/using-zynaptik-module-for-encoders-solved/3751>\
**Category:** Hardware\
**Created:** [January 9, 2020, 6:43pm UTC](https://discourse.zynthian.org/t/using-zynaptik-module-for-encoders-solved/3751 "2020-01-09T18:43:04Z")\
**Posts on this page:** 1\
**Showing post:** 12
<div class="post-metadata">
**Author:** ![jofemodo](https://discourse.zynthian.org/user_avatar/discourse.zynthian.org/jofemodo/32/2_2.png) [@jofemodo](https://discourse.zynthian.org/u/jofemodo)\
**Post date:** [January 10, 2020, 8:27pm UTC](https://discourse.zynthian.org/t/using-zynaptik-module-for-encoders-solved/3751/12 "2020-01-10T20:27:43Z")
</div>
Your MCP23017 is alive, so if you:
- changed the port in zyncoder source code + re-build
- connected the encoders in the right way
- choose the right configuration in webconf
It should work 😉
I suppose you are using this info:
> [@CV/Gate input/output](https://discourse.zynthian.org/t/cv-gate-input-output/3182/7):
> OK! I’ve a zynaptik with all the parts soldered on it: The second 40-pin connector is the “zynaptik connector” and has this pin-out: Where: GPAx & GPBx are digital input/output pins (MCP23017, at I2C address 0x21) INTA & INTB are interrupt pins for banks GPAx & GPBx, connected to RBPi pins 36 & 37. AD-x are analog input pins (ADS1115) DA-x are analog output pins (MCP4728) I will copy this info to the wiki ASAP wink Regards,
![](https://discourse.zynthian.org/uploads/default/original/2X/d/dbec3563d8723c83768684e6595439237ee00717.png)
_[View the full topic](https://discourse.zynthian.org/t/using-zynaptik-module-for-encoders-solved/3751)._
