I’m new here and just got Zynthian V4.2 Kit and enjoyed a bit. I’m now trying not to use the Zynthian OS but use Raspberry Pi OS and enabling ZynScreen.
I just copied /boot/config.txt on the SD card but the screen does not turn on. I tried to use GPIO #18 to turn the backlight on but did not get success.
Does anyone know how to use it without Zynthian OS?
Thank you for your help. I copied the file to /boot/overlays and added followings into /boot/cmdline.txt
fbcon=map:10 fbcon=rotate:0 fbcon=font:ProFont6x11
And did gpis -g write 22 1, the backlight turned on but the screen shows white. Are there any extra steps I need to use the ZynScreen v1.5?
When I use Zynthian OS and added the cmdline then it shows console message at boot, but not working for clean installed Raspberry Pi OS.
Zynthian uses some patched versions of various libraries or specific versions. This is why apt upgrade will break a Zynthian. You may find some libraries in a stock distribution do not work.
