V5 Touch buttons on the Zynthian V4 (SOLVED)
You may look if the Switch Action 21 - 24 correspond as well as you have the pins at position 21 to 24 (behind the row of “-1”) set up correctly. I could imagine that the customization profile would be rather “V5” if the virtual touch buttons would be V5 buttons?
With this configuration everything works:
100,102,101,103,104,105,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
I can now remove the two buttons 104 and 105… they were used for PLAY(STOP) and RECORD… but now I can do these things from the display.
P.S.
The two touch buttons OPT/ADMIN and MIX/LEVEL do not work. But now I’m checking that there is no conflict… for now I’m very satisfied… Thanks
PP.SS.
After the reboot everything works, both the encoders and the touch… PERFECT!
Last question… I used to use Zynsampler to have an audio track to follow (MP3) and play along. Now I see that with the Play arrow on the display I start the base, but it is separate, it has nothing to do with Zynsampler… it’s fine, but I can’t control the volume… If the base is too loud, how do I lower it? Since it’s not visible on the mixer, can’t I adjust the volume while I play?
The global audio play may be accessed with bold press of play button.
Perfect! Thanks @riban. Now I can delete the Zynsampler channel from the snapshot. Zynthian does what I wanted it to do. Thanks
Oh, I missed this, but I am glad you found how it works. It took me some time too, as seen in the other thread.
Yes, you need to have at least 24 switches configured in order to assign any function to them, even if they are “virtual” (not physically connected to any GPIO pin - that is what “-1” means). The first four are the V4 encoder switches and then come the 20 V5 “buttons”. If you use(d) some real physical buttons on positions 5-24 before, they would duplicate the function of the corresponding V5 buttons at the same position (as configured in the V5 profile). So, if you wanted to use them in addition to those 20 buttons, you would need to move them to position 25 and higher. (The other option would be to reconfigure the whole V5 profile, but I guess that would be more tedious.)
I wondered whether all the 36 (was it?) buttons could not be just automatically available by default and pre-configured to the virtual “-1”, unless explicitly configured otherwise. @jofemodo mentioned that he pre-configured something like that for the “Dummies” profile, at least. Maybe there is more in the way to make it a general default that I have not noticed.
