I’m seeing a graphical glitch on the latest version of Vangelis. Picture attached, essentially it appears that the top two rows of pixels are incorrectly displaying the bottom of the screen. Occasionally, it’s much worse with the top centimeter or so being fence-posted between correct and corrupt pixels, but this failure mode is persistent to 90% of boots. Is anyone else experiencing something similar or should I explore replacing my ribbon cable?
I have carefully removed and re-seated both sides of both ribbons cables.
When I swap to my Oram SD card, the issue goes away. It comes back upon swapping the SD card to Vangelis.
Software update through web-ui performed.
Full Vangelis reflash to the latest 2026-09-30 build from this thread.
Hardware is the official V5.1 kit, running on the official (US) power supply. MIDI in plugged into the output of a Keystep Pro and the audio outputs are plugged into a Xenyx1002SFX mixer.
Hi! I`m quite new to Zynthian, but I have been enjoying the latest beta this weekend. (And lurking in the forum for some time)
Amazing work!
However noticed that Mackie Control is acting a little differently now then the last version. Has it changed? The faders on my midi controller/mixer (Samson Graphite MF 8) no longer moves the mixer fader, but only activates the “active chain”.
Would be cool to be able to use the faders with Mackie Control rather then having to assign/learn, but it`s not a big issue.
The mackie driver has been refactored for Vangelis, but the basic functionality should remain the same, with some improvements. While refactoring i’ve tested with 2 different MCU controllers:
Mackie Logic Control (one of the original devices)
Behringer Motör 61
I think others have tested with XTouch and perhaps others.
Perhaps you need to configure your MF8. Are you aware of the Mackie config panel in the webconf?
Anyway, i didn’t know about this tiny MIDI controller and it’s surprising it supports MCU.
Yep. I can confirm this. The simple MIDI “arpeggiator” seems to be broken as it doesn’t sync to host tempo. I remember it did in the past, and we have not updated this plugin recently, so most probably something in the way zynthian manages clock/tempo has changed and broken the plugin behavior.
QMidiArp still work perfectly OK, and other plugins synced to host tempo too.
It would be good to check all of them to see if there is some other plugins failing to sync.
I’ve been holding my breath and still have Oram booting from my NVMe, although I’m looking forward to move on, as soon as more experienced folks start talking about it Also, I recall @riban mentioned at some point that he was willing to somehow adding the process to the standard Z image… Any ideas? Thanks
Thanks, just ran the script and everything looks fine, no extensive testing yet, but very promising! The reason I asked is because, although I dont read everything on this forum, I understood that there were some changes in the folderstructure, so I wanted to know if that could be an issue.
