hi there i was wondering if it would be possible to have vcf frequency and resonance on the same page in some modui plugins (jx10,Nekobi,etc) or maybe another page layer to choose which controllers to map to x,y touchpad.
cheers
cheers
Hi @martindunne!
Moving some controllers to other pages wont solve the true problem. What we need is to select whatever 2 parameters to the XY controller. Iāve think about how to solve this issue frequently, but until now i havenāt found a decent solution. Perhaps itās time to open the question to the community and make some brain storming
The problem: Currently the XY controller works by clicking 2 parameters simultaneously. This is pretty intuitive but in that way you canāt select parameters from different pages.
The goal: We need a way of accessing the XY controller selecting 2 parameters from different pages.
The restricitions:
Some ideas?
Could the MIDI filters do something?
Presumably we are ultimately looking at mapping two independent MIDI control channels onto X & Y?
Are there not two user approaches to thisā¦?
Without more hardware you aināt going to get much more intuitive functionality and the more complex the āspecialā modes the less people will probably access it.
What about this:
If You are on the x-y controller screen, bottom left-right encoders control the x-y values (useful without touch screen). Upper left-right encoders change the x-y controllers with short (1-2 sec) CC number and name presentation on the screen. Buttons behave as the other screens, exit the x-y screen with the Back button.
MIDI is not the only mechanism used for changing parameters. OSC is also used, and MOD-UI uses its own specific protocol (websocket).
When the MIDI-learning is implemented for all engines, that could be a way, but it is still not a straightforward method of selecting 2 parameters for the XY controller screen.
This would work, but Itās a 2 steps way and worst, you have to repeat the selection everytime you enter. Anyway, IMHO itās the best proposal until now
Hi @Zynthianers!
Iāve implemented a new workflow for the XY-Controller. It works like that:
This workflow is experimental but solves the problem quite well. I would like to get some feedback from you ā¦
hi there using it in modui with jx10 i dont seem to be able to get a range its either off when i am moving the xy and on when i go off the edge of the xy screen.
thanks
Itās working now with float values, but the pre-selection is failing with MOD-UI.
I will fix it tomorrow
working well now great solution to the problem many thanks
Itās fixed now. It should work perfectly with all engines, allowing selection of parameters from different pages.
Please, send feedback and ā¦ if somebody figures a better workflow for the XY-Controller, donāt hesitate to tell us!!
Enjoy!!
Just a reminder that the wiki still refers to the old method of assigning XY parameters
Edit: nvm the new method also doesnāt seem to work, was this cut?
Btw I wouldnāt mind contributing to the wiki from time to timeā¦
