I´m having problems with mod-ui. Audio drops after a few minutes and cpu light blinks red and several xruns. This happens even if no plugins are in use. Zynthian gui/encoders etc works as exspected.
My Raspberry:
Raspberry-pi3
Official 7" TFT
Audioinject Zero
Running at 48KHz
Fresh installed gorgona edge 2017-10-23
updated numerous times via zynthian gui
I´ve reflashed several times and after x retries I´m a bit confused how to solve this.
Is this a USB device? I think so… USB is not really supported. I think the problem occurs due to driver problems.
If this happens you can try to restart jack. But this also means you have to restart mod-host, mod-ui and a2jmidid - so a complete reboot is nearly the same.
Do you have any loaded plugins inside mod-ui or does the CPU load problem occur without anything loaded?
You can try to chage the parameters for jack in the webgui: try to use 44.1kHz and more buffers:
For the buffers: I told you not really the right thing. Here is the more technical explanation of man jackd:
-n, --nperiods int
Specify the number of periods of playback latency. In seconds,
this corresponds to --nperiods times --period divided by --rate.
The default is 2, the minimum allowable. For most devices, there
is no need for any other value with the --realtime option. Withâ
out realtime privileges or with boards providing unreliable
interrupts (like ymfpci), a larger value may yield fewer xruns.
This can also help if the system is not tuned for reliable realâ
time scheduling.
For most ALSA devices, the hardware buffer has exactly --period
times --nperiods frames. Some devices demand a larger buffer.
If so, JACK will use the smallest possible buffer containing at
least --nperiods, but the playback latency does not increase.
For USB audio devices it is recommended to use -n 3. Firewire
devices supported by FFADO (formerly Freebob) are configured with
-n 3 by default.
Hifiberries seem to work with -n2. You should also try -r 48000 -n3 (if you really need 48kHz) or -r44100 -n2 (I would like to recommend the last one).
