ZynAddSubFX on Vangelis - no sound from presets
Dear community,
first of a ll a big thank you the all that have made this project a reality. I received and built my kit last week and almost everything worked out of the box (after reseating the control board cable ;-)). I am having a lot of fun playing it from a Linnstrument 128 controller (at the moment still in non-MPE mode on the side of the Linnstrument).
Also all of the preinstalled synths and their presets seem to work fine - except Zynaddsubfx. There, all the UI seems to be working but I cannot get sound from any of the presets once they have been selected. Is there anything special about this particular synth that needs additional configurations in the chain, or that is special on the MIDI input side? Or, is there anything that I may have misvlicked that will mute a whole synth for all chains, even new ones?
I can’t think of anything about Zynaddsubfx that would cause no sound. Does Zynaddsubfx react to midi on the meters visually? Are you running Oram or Vangelis? If Oram, I would try downloading and flashing a new SD card with Vangelis as it is now (very recently) the stable and supported version. If the problem persists with Vangelis, please provide a copy of the main screen, AKA “Dashboard” from webconf.
I do run Vangelis (oddly it downloaded when clicking the latest stable link that still had oram in its name two days ago, while today the link name indeed says vangelis. Maybe I downloaded exactly around the time of the link-edit?).
I see parameters in ZynAddSubFx react to turning the controller nobs. The behaviour is also specific to this synth engine. When I replace it by any other synth engine (in the same change), I do get sound.
I will start with another chain from scratch again and investigate some. Since no one else has reported that problem it may be that I screwed up something over here.
Sounds good. I just tried it here adding a Zynaddsubfx chain and “A VDX” preset and got sound.
Hi :slight_smile:,
What do you exactly mean by “controller knobs”? Are you maybe using an external control surface with rotary encoders, to program patches and do sound design or send sequences?
If so, please do remember that Zynadd is a multitimbral synth engine: are you driving the chain with the loaded plugin in active mode (play the selected chain whatever the input Midi channel) or multitimbral mode? (play the engine’s chain if the incoming Midi data matches the chain’s channel)
Please, be aware that, in the latter case, you may not get any sounds if your current Zynadd preset is loaded on a plugin’s multitimbral channel (on the native GUI in VNC) other than Midi 1. Not at home to practically verify: just speculating.
Cheers
Thanks for the reply.
Just to clarify, when I said controller knobs, I meant the four rotary encoders on the zynthian itself that can be used to control some of the preset parameters.
I am still not sure what created the hang up. I had one more occasion, where ZynAddSubFX lost its sound and the active chain sort of auto-switched to the other chain in the project and activated it.
I do not want to rule out that the Linnstrument may send some weird unintended MIDI sometimes.
However, I now play two instances of ZynAddSubFx using the multitimbal MIDI mode on the zynthian, giving each chain a specific MIDI channel and on the Linnstrument I use the non-MPE mode, and the split mode, such that one half of the instrument sends MIDI notes on channel 1 and the other of channel 16. Since then I have not had any problem (for about an hour).
I will come back to this if I encounter problems again.
I just wonder now what you meant by saying that Zynadd is in itself a multimbral engine - do you mean that some presets themselves are multitimbral and require both, multitimbral mode on the zynthian (or don’t) and a specific collection of MIDI channels for that chain?
If you navigate its native GUI on VNC, you can see that it offers 16 multitimbral parts and Midi channels. This feature has been automatically integrated in Zynthian for a long time: each new chain and Midi channel armed with Zynadd occupies the related multimbral slot of the same Zynadd instance, without the need to reload several times the same engine.
Thanks for clarifying. So to check my understanding: If I add multiple chains, each having a Zynadd processor (in zynthian speak) and each listening to a specific MIDI channel, then on the software side it really is only one Zynadd engine running and each instrument chain consumes one slot of the multitimbral engine, right?
Yes, just right! :+1:.
That it also why Zynadd has been a staple of the Zynthian’s synthesiser weaponry from the very beginnings, and possibly, I suspect, also one of the linguistic seeds for the project’s name itself (Zyn - Zyn).
Zynadd is very cleverly coded, highly optimised, sounds gorgeous and is markedly resource-effective. Therefore, it was among the Zynthian’s crown jewels when the hardware was considerably less powerful than V 5.1, and saving computational resources towards achieving multitimbral snapshots was a paramount requirement.
Best regards :slight_smile:
