i’m trying to get working an old RPI2 with 3.5 pi screen.
Screen is working byt i get an error with the ip address. I checked al lot in the forum but i didn’t find anithing working.
Jan 30 22:58:45 zynthian startx[1328]: Building XImage…done
Jan 30 22:58:52 zynthian systemd[1]: zynthian.service: Stopping timed out. Terminating.
Jan 30 22:58:52 zynthian systemd[1]: zynthian.service: Control process exited, code=killed, status=15/TERM
Jan 30 22:58:52 zynthian startx[1328]: xinit: connection to X server lost
Jan 30 22:58:52 zynthian startx[1328]: [1B blob data]
Jan 30 22:58:52 zynthian startx[1328]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Jan 30 22:58:53 zynthian startx[1328]: xinit: unexpected signal 15
Jan 30 22:58:53 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Jan 30 22:58:53 zynthian systemd[1]: zynthian.service: Failed with result ‘timeout’.
Jan 30 22:58:53 zynthian systemd[1]: Stopped Zynthian User Interface.
Jan 30 22:58:53 zynthian systemd[1]: Started Zynthian User Interface.
Jan 30 22:58:53 zynthian startx[1479]: X.Org X Server 1.20.4
Jan 30 22:58:53 zynthian startx[1479]: X Protocol Version 11, Revision 0
Jan 30 22:58:53 zynthian startx[1479]: Build Operating System: Linux 4.15.0-99-generic armv8l Raspbian
Jan 30 22:58:53 zynthian startx[1479]: Current Operating System: Linux zynthian 4.19.118-v7+ #1311 SMP Mon Apr 27 14:21:24 BST 2020 armv7l
Jan 30 22:58:53 zynthian startx[1479]: Kernel command line: coherent_pool=1M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Jan 30 22:58:53 zynthian startx[1479]: Build Date: 07 July 2020 09:38:51PM
Jan 30 22:58:53 zynthian startx[1479]: xorg-server 2:1.20.4-1+rpt2 (Debian -- Support)
Jan 30 22:58:53 zynthian startx[1479]: Current version of pixman: 0.36.0
Jan 30 22:58:53 zynthian startx[1479]: Before reporting problems, check http://wiki.x.org
Jan 30 22:58:53 zynthian startx[1479]: to make sure that you have the latest version.
Jan 30 22:58:53 zynthian startx[1479]: Markers: (–) probed, (**) from config file, (==) default setting,
Jan 30 22:58:53 zynthian startx[1479]: (++) from command line, (!!) notice, (II) informational,
Jan 30 22:58:53 zynthian startx[1479]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Jan 30 22:58:53 zynthian startx[1479]: (==) Log file: “/var/log/Xorg.0.log”, Time: Sat Jan 30 22:58:53 2021
Jan 30 22:58:53 zynthian startx[1479]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Jan 30 22:58:53 zynthian startx[1479]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Jan 30 22:58:56 zynthian systemd[1]: Stopping Zynthian User Interface…
Jan 30 22:58:56 zynthian startx[1479]: Terminated
Jan 30 22:58:57 zynthian startx[1479]: PNG file: /zynthian/config/img/fb_zynthian_error_ip.png - Application must supply a known background gamma
Jan 30 22:58:57 zynthian startx[1479]: /zynthian/config/img/fb_zynthian_error_ip.png is 480x320 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4546
Jan 30 22:58:57 zynthian startx[1479]: Zooming image by 100%…done
Jan 30 22:58:57 zynthian startx[1479]: Merging…didn’t find evidence of prior run.
Jan 30 22:58:57 zynthian startx[1479]: done
Hi, welcome
This error occurs when jack sound serveur doesn’t start. They where some troubles with the raspi builtin headphone. And I think some fixes has bien done.
Try to update your zynthian software through the webconf and restart.
Thank you but already did update. Even if I choose Dummy audio I get the same error.
– Logs begin at Sun 2021-01-31 12:04:50 GMT. –
Jan 31 12:06:44 zynthian startx[1321]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Jan 31 12:06:44 zynthian startx[1321]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Jan 31 12:06:46 zynthian systemd[1]: Stopping Zynthian User Interface…
Jan 31 12:06:46 zynthian startx[1321]: Terminated
Jan 31 12:06:47 zynthian startx[1321]: PNG file: /zynthian/config/img/fb_zynthian_error_ip.png - Application must supply a known background gamma
Jan 31 12:06:47 zynthian startx[1321]: /zynthian/config/img/fb_zynthian_error_ip.png is 480x320 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4546
Jan 31 12:06:47 zynthian startx[1321]: Zooming image by 100%…done
Jan 31 12:06:47 zynthian startx[1321]: Merging…didn’t find evidence of prior run.
Jan 31 12:06:47 zynthian startx[1321]: done
Jan 31 12:06:47 zynthian startx[1321]: Building XImage…done
Jan 31 12:06:55 zynthian startx[1321]: lilv_world_load_bundle(): warning: Replacing version 2071.7 of http://gareus.org/oss/lv2/b_whirl#extended from <file:///zynthian/zynthian-plugins/lv2/b_whirl.lv2/>
Jan 31 12:06:55 zynthian startx[1321]: lilv_world_load_bundle(): note: New version 2071.11 found in <file:///zynthian/zynthian-plugins/lv2/b_whirl/>
Jan 31 12:06:55 zynthian startx[1321]: lilv_world_load_bundle(): warning: Replacing version 2071.7 of http://gareus.org/oss/lv2/b_whirl#simple from <file:///zynthian/zynthian-plugins/lv2/b_whirl.lv2/>
Jan 31 12:06:55 zynthian startx[1321]: lilv_world_load_bundle(): warning: Ignoring bundle <file:///zynthian/zynthian-plugins/lv2/b_synth.lv2/>
Jan 31 12:06:55 zynthian startx[1321]: lilv_world_load_bundle(): note: Newer version of http://gareus.org/oss/lv2/b_synth loaded from <file:///zynthian/zynthian-plugins/lv2/b_synth/>
Jan 31 12:06:59 zynthian startx[1321]: Cannot connect to server socket err = No such file or directory
Jan 31 12:06:59 zynthian startx[1321]: Cannot connect to server request channel
Jan 31 12:06:59 zynthian startx[1321]: jack server is not running or cannot be started
Jan 31 12:06:59 zynthian startx[1321]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Jan 31 12:06:59 zynthian startx[1321]: libjackpeak failed to start jack client: 17
Jan 31 12:06:59 zynthian startx[1321]: PNG file: /zynthian/config/img/fb_zynthian_error_ip.png - Application must supply a known background gamma
Jan 31 12:06:59 zynthian startx[1321]: /zynthian/config/img/fb_zynthian_error_ip.png is 480x320 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4546
Jan 31 12:06:59 zynthian startx[1321]: Zooming image by 100%…done
Jan 31 12:06:59 zynthian startx[1321]: Merging…done
Jan 31 12:06:59 zynthian startx[1321]: Building XImage…done
Jan 31 12:07:06 zynthian systemd[1]: zynthian.service: Stopping timed out. Terminating.
Jan 31 12:07:06 zynthian systemd[1]: zynthian.service: Control process exited, code=killed, status=15/TERM
Jan 31 12:07:06 zynthian startx[1321]: xinit: connection to X server lost
Jan 31 12:07:06 zynthian startx[1321]: [1B blob data]
Jan 31 12:07:06 zynthian startx[1321]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Jan 31 12:07:07 zynthian startx[1321]: xinit: unexpected signal 15
Jan 31 12:07:07 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Jan 31 12:07:07 zynthian systemd[1]: zynthian.service: Failed with result ‘timeout’.
Jan 31 12:07:07 zynthian systemd[1]: Stopped Zynthian User Interface.
Jan 31 12:07:07 zynthian systemd[1]: Started Zynthian User Interface.
Jan 31 12:07:08 zynthian startx[1492]: X.Org X Server 1.20.4
Jan 31 12:07:08 zynthian startx[1492]: X Protocol Version 11, Revision 0
Jan 31 12:07:08 zynthian startx[1492]: Build Operating System: Linux 4.15.0-99-generic armv8l Raspbian
Jan 31 12:07:08 zynthian startx[1492]: Current Operating System: Linux zynthian 4.19.118-v7+ #1311 SMP Mon Apr 27 14:21:24 BST 2020 armv7l
Jan 31 12:07:08 zynthian startx[1492]: Kernel command line: coherent_pool=1M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Jan 31 12:07:08 zynthian startx[1492]: Build Date: 07 July 2020 09:38:51PM
Jan 31 12:07:08 zynthian startx[1492]: xorg-server 2:1.20.4-1+rpt2 (Debian -- Support)
Jan 31 12:07:08 zynthian startx[1492]: Current version of pixman: 0.36.0
Jan 31 12:07:08 zynthian startx[1492]: Before reporting problems, check http://wiki.x.org
Jan 31 12:07:08 zynthian startx[1492]: to make sure that you have the latest version.
Jan 31 12:07:08 zynthian startx[1492]: Markers: (–) probed, (**) from config file, (==) default setting,
Jan 31 12:07:08 zynthian startx[1492]: (++) from command line, (!!) notice, (II) informational,
Jan 31 12:07:08 zynthian startx[1492]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Jan 31 12:07:08 zynthian startx[1492]: (==) Log file: “/var/log/Xorg.0.log”, Time: Sun Jan 31 12:07:08 2021
Jan 31 12:07:08 zynthian startx[1492]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Jan 31 12:07:08 zynthian startx[1492]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Jan 31 12:07:10 zynthian systemd[1]: Stopping Zynthian User Interface…
Jan 31 12:07:10 zynthian startx[1492]: Terminated
Jan 31 12:07:11 zynthian startx[1492]: PNG file: /zynthian/config/img/fb_zynthian_error_ip.png - Application must supply a known background gamma
Jan 31 12:07:11 zynthian startx[1492]: /zynthian/config/img/fb_zynthian_error_ip.png is 480x320 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4546
Jan 31 12:07:11 zynthian startx[1492]: Zooming image by 100%…done
Jan 31 12:07:11 zynthian startx[1492]: Merging…didn’t find evidence of prior run.
Jan 31 12:07:11 zynthian startx[1492]: done
Jan 31 12:07:11 zynthian startx[1492]: Building XImage…done
Edit: If you want to have a go then I think minisynth will be great on the pi 2. It’s a pain to cross-compile though so give me a shout if you get stuck.
yes, already done with a i2s cheap 51xx dac and oled screen.
It works well for old dos game with midi compatibility and so.
You can also play with a midi keyboard but with the limited polyphony of an mt32 (don’t ask for 256 voices with a rpi2).
