anyone have zynthian os image complete to navigate and control the Zynthian UI without all in one module encoders/switches at all. Only touchscreen
I’ve worked with waveshare touchscreen only, no encoders.
can you share it please wyleu
I will rebuild the rig to see how it functions ( With the Motor 61 ) I don’t remember too many details except I ran it as zynthian-amp.local for a while but broke it down for some reason ( long forgotten) .
The only element of configuring the WaveShare 7 Screen
(With HDMI & usb in my case) is to select it in the Display section
and then in the encoder section just select Dummies which is no encoders.
A normal zynthian image should get you to the stage where you can point a browser at zynthian.local and set it up from there.
That’s all I’d do to set it up. Because the next stage after that is to give it a local name
Screen Works fine. ( After the traditional Two MIDI devices plugged into USB Error Roland A-88 and Motor 61…)
Touch doesn’t at the moment, but the screen is powered by usb so it’s obviously connected.
@tedy are you happy with copying down a zynthian image?
Getting Zynthian software
zynthian os image complete to navigate and control ,no all in one module like this image 7 inch control suport without all in one module rotary switch encoder https://www.youtube.com/watch?v=mqS01SI_iiw
