Adventures in pipewire
So, spurred on by the meeting at ZynthianClub I did a bit of poking about with pipewire in Zynthian. Which is roughly documented here
In short, I got pipewire working using the supplied packages, ran some synths, connected midi inputs and audio outputs, had a go with switching between the hifiberry and a usb audio device, ran with multiple outputs, and it all worked.
Next I want to wrangle automating connections with wireplumber, so when I unplug the usb device it automatically switches back to the hifiberry, and back when you plug it back in.
Then I guess I want to rip the zynmixer out from the rest of the code and run it on top.
I didn’t do anything with setting the latency, it seemed as good as Jack for me.
By the way, how do you measure latency ? A loop from audio out to audio in and a engine that give the result ??
You can do that but most of the time it’s calculated internally from how many periods and samples you set the jack config to.
The way I tend to do it is record the output triggered from a midi keyboard against the keyboard audio.
Jack provides a tool to do this (within jack and I suppose jack emulation in pipewire) called jack_delay that appears as a source and destination within the routing graph and measures the time between the audio it produces and it receives. You loop the audio at the physical i/o to get full round-trip latency measurment.
@riban @jofemodo How do I get the zynmidirouter to load without complaining jack isn’t running. The synths (setbfree & jalv) just link to the jacklib, so they run with the pipewire compatibility lib. But the router complains about jack and dies.
You have to run it in an environment that knows about Pipewire’s jack emulation. I can’t remember exactly but I think there is an env var you should set. I had to do that each time and couldn’t figure out how to make it work automatically.
You shouldn’t need the environment variable if you re-order the library load order.
This is how I setup the environment.
apt update
sudo apt install pipewire-audio pipewire-jack
cp /usr/lib/systemd/user/pipewire.* /etc/systemd/user
sed -i 's/^ConditionUser=!root/# ConditionUser=!root/' /etc/systemd/user/pipewire.{service,socket}
touch /etc/pipewire/media-session.d/with-jack
cp /usr/share/doc/pipewire/examples/ld.so.conf.d/pipewire-jack-aarch64-linux-gnu.conf /etc/ld.so.conf.d/0-pipewire-jack-aarch64-linux-gnu.conf
ldconfig
systemctl --user daemon-reload
systemctl daemon-reload
systemctl disable --now zynthian jack2
systemctl --user enable --now wireplumber
pw-play /usr/share/sounds/alsa/Front_Left.wav
I also have to mask the jack2 service because it loves to jump in and interfere.
The midi router is doing “some test” that the softsynths don’t bother with.
Unless it has some other environment variable I haven’t spotted.
I got it working but had to start Zynthian with the pipewire launch tool. I didn’t resolve that issue.
The library reorder should solve that.
ldconfig
Well, I’ve got it to move on a tiny bit further…
But now something is segfaulting.
ooming image by 150%...done
  Merging...  Clipping image...done
done
didn't find evidence of prior run.
  Building XImage...done
ZynCore: Configured 4 x Logical Zynswitches...
ZynCore: Setting-up 4 x Physical Zynswitches...
ZynCore: Setting-up 4 x Zynpots (zyncoders)...
ZynCore->gpiod_start_callbacks: Callback thread created successfully
Started libzynaudioplayer using libsndfile-1.2.0
Started libzynmixer
./zynthian.sh: line 270: 3096269 Segmentation fault      ./zynthian_main.py
/zynthian/config/img/fb_zynthian_message.png is 480x320 PNG image, color type RGB_ALPHA, 8 bit
  Zooming image by 150%...done
done
Ah, this is the error I was seeing before. “Error connecting with Jack server”
24 15:43:23 zynthian startx[3096970]: ZynCore: Configured 4 x Logical Zynswitches...
Aug 24 15:43:23 zynthian startx[3096970]: ZynCore: Setting-up 4 x Physical Zynswitches...
Aug 24 15:43:23 zynthian startx[3096970]: ZynCore: Setting-up 4 x Zynpots (zyncoders)...
Aug 24 15:43:23 zynthian startx[3096970]: ZynCore->gpiod_start_callbacks: Callback thread created successfully
Aug 24 15:43:23 zynthian startx[3096970]: ZynMidiRouter: Error connecting with jack server.
Aug 24 15:43:23 zynthian startx[3096970]: ERROR:zynthian_gui_config.<module>: lib_zyncore: Failed to initialise zynmidirouter (2)
Aug 24 15:43:23 zynthian startx[3096989]: /zynthian/config/img/fb_zynthian_message.png is 480x320 PNG image, color type RGB_ALPHA, 8 bit
Aug 24 15:43:23 zynthian startx[3096989]:   Zooming image by 100%...done
Aug 24 15:43:23 zynthian startx[3096989]:   Merging...done
Aug 24 15:43:23 zynthian startx[3096989]:   Building XImage...done
Aug 24 15:43:34 zynthian startx[3097000]: ZynCore: Configured 4 x Logical Zyn
The exact point it is segfaulting is when it instantiates the zynthian mixer lib
using gdb shows that for some reason its failing to load a different library?
[New Thread 0x7fe53ef180 (LWP 867459)]
Started libzynmixer
Thread 12 "python3" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fe5bff180 (LWP 867458)]
__GI___memset_generic () at ../sysdeps/aarch64/memset.S:86
86      ../sysdeps/aarch64/memset.S: No such file or directory.
(gdb) bt
#0  __GI___memset_generic () at ../sysdeps/aarch64/memset.S:86
#1  0x0000007fe6412da4 in onJackProcess () from /zynthian/zynthian-ui/zynlibs/zynmixer/build/libzynmixer.so
#2  0x0000007ff5e64dd8 in ?? () from /usr/lib/aarch64-linux-gnu/pipewire-0.3/jack/libjack.so.0
#3  0x0000007ff5cf8928 in ?? () from /usr/lib/aarch64-linux-gnu/spa-0.2/support/libspa-support.so
#4  0x0000007ff5d78a7c in ?? () from /lib/aarch64-linux-gnu/libpipewire-0.3.so.0
#5  0x0000007ff7d4ee58 in start_thread (arg=0x7fffff7797) at ./nptl/pthread_create.c:442
#6  0x0000007ff7db7f9c in thread_start () at ../sysdeps/unix/sysv/linux/aarch64/clone.S:79
(gdb)
that ../sysdeps/aarch64/memset.S looks like the problem maybe? I don’t know if the backtrace helps.
It looks like it is certainly loading the pipewire jack lib though.
Ah, I misunderstood the error. GDB is trying to load the source for the memset function but it’s not installed.
So I guess it’s something about these lines where memset is called:
If that is the trigger then either pNormalisedBufferA/B is not initialised or sizeof(jack_default_audio_sample_t) is returning an invalid value. I wonder if the buffers are defined with this data type?
[Edit] Buffers are defined as pointers to jack_default_audio_sample_t so that looks okay. Maybe there is an issue with the default audio data size. Maybe pipewire uses a different audio data size. Maybe the lib needs to be recompiled against the pipewire jack compatibility layer. Try recompiling audio mixer. Ensure the dev packages for pipewire (jack layer) are installed.
That didn’t seem to make much of a difference.
I also tried commenting out the two lines, and it segfaulted in a different memory location and then powered off the pi which made getting a backtrace a little more tricky. So I think we’re close
ok I compiled with debugging symbols, here is the backtrace. nFrames is set to 1024 pArgs is 0x0
Thread 2 "python3" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 1525.1627]
(gdb) bt
#1  0x0000007fe6412da4 in onJackProcess (nFrames=1024, pArgs=0x0) at /zynthian/zynthian-ui/zynlibs/zynmixer/mixer.c:159
#2  0x0000007ff5b34dd8 in on_rtsocket_condition (data=0x2937920, fd=<optimized out>, mask=<optimized out>)
    at ../pipewire-jack/src/pipewire-jack.c:1546
#3  0x0000007ff59c8928 in ?? () from target:/usr/lib/aarch64-linux-gnu/spa-0.2/support/libspa-support.so
#4  0x0000007ff5a48a7c in ?? () from target:/lib/aarch64-linux-gnu/libpipewire-0.3.so.0
#5  0x0000007ff7d4ee58 in start_thread (arg=0x7fffffd417) at ./nptl/pthread_create.c:442
so I set the buffers to 256 as describe here:
https://linuxmusicians.com/viewtopic.php?t=25768
pw-metadata -n settings 0 clock force-quantum 256
and it doesn’t segfault anymore. It doesn’t load properly either. it’s stopped on the zynthian loading screen and the log hangs at:
Process python3 created; pid = 1540
Listening on port 12345
Remote debugging from host ::1, port 57490
lib_zyncore_init() fails unless zynthian_gui_config.py is run with pw-jack wrapper. It looks like initiating a library loaded with cdll fails to use the configured pw-jack lib defined with /etc/ld.so.conf.d/0-pipewire-jack-aarch64-linux-gnu.conf.
Also, even launching zynthian with pw-jack wrapper fails because setting aliases fails (maybe not supported by pipewire?) and soundcard port names are all rather odd, like 7.1 names rather than simple input/output 1,2,3…
That might be due to a (wrong) default profile.
Try to set the profile to “Pro Audio”, that changes the naming to SOMETHING 1,2,3,…, at least at my workstation…
I spent some time today trying to get pipewire working bit failed. I got sound out but there are challenges to make zynthian work. I came to the conclusion that we probably should not try to get zynthian working in top of the pw-jack abstraction / interface layer. We will spend a lot of time and effort to get to a suboptimal compromise. If it were quick and easy then there may be benefit but that seems unlikely. Instead we should get zynthian working natively with pipewire. We would still require the pw-jack plugin for jalv and possibly other engines.
If someone wants to do this then feel free. I am yet to be convinced that there is sufficient benefit. It’s is something worth investigating because jack may become unsupported but we don’t need to move away from jack yet.
Hotplug, multidevice support and the handy tools for tracing xruns are the possible arguments for pipewire, some of which we have now. Maybe support for lowlatency bluetooth in the future. And the fact it’s fairly well maintained I suppose.
We have hotplug, multidevice support. We have BLE. Jack is currently supported. So, IMO insufficient benefit to dedicate effort (yet) but… feel free to make it work! :wink:
